Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 07-10-2009, 08:41 AM
Countryman is on a distinguished road
What are 'post-processors'?
I am just getting into CNC and am reading up on CAM packages. One claims to have "100s of post-processors". What are these and what are they for? The blurb obviously assumes I should know!
Thanks.
Old 07-10-2009, 08:57 AM
beege's Avatar
beege is on a distinguished road
Every machine tool has their proprietary programming quirks and abilities. You CAM package doesn't know which machine you are going to use, or how you like to see the program compiled. It will take your inputs, and, using the proper post, output a program that suits you and the application. If then you have a different machine, with different quirks, then you'd re-post for that machine.
Old 07-10-2009, 09:39 AM
Ah, thanks beege. I am using Mach3 so I guess that I ned to buy a CAM package with an M3 post-processor.
Cheers.
Old 07-10-2009, 10:29 AM
James L is on a distinguished road
Lazy Cam
Mach 3 comes with a free CAM program called lazy cam that is useful for small projects. I have had no problems loading posted code made for other machines into mach3 also. I have also been able to run code made for mach3 on a haas machine as well with only minor adjustments.
Old 07-15-2009, 06:55 AM
STUGOD's Avatar
STUGOD is on a distinguished road
DOING A LITTLE BLOG ON TURBO CAD TAKE A http://wwwstugod.blogspot.com/ FROM stugod
post processors littlerob Okuma 6 12-06-2008 11:26 AM
Need Help!- how do I set my post processors Alan0166 BobCad-Cam 2 09-16-2008 06:53 AM
post processors? john_t_h Syil Products 6 03-31-2008 06:11 PM
V20 post processors doug6949 BobCad-Cam 5 02-22-2005 07:49 AM
post processors Turn Man General CAM Discussion 4 05-30-2004 01:13 PM
