Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 02-13-2005, 02:14 PM
belgrado is on a distinguished road
Question wich program should I choose
Hello ,
I'm about to build my first cnc router set up .( and a second small one afterwards )
I've been looking at lot's of websites over the past years .
Mechanically everything is decided but as far as controller software I'm not sure yet .
My main purpose would be making guitars or guitarparts with it .
I was thinking about Turbocnc . ( It seems very universal )
Is this program very reliable and straightforward to use .
Most of the stuff will be 2 1/2 d but later I would try to go for complex surface routing .
I would apprieciate any recommendations.
Paul
Old 02-13-2005, 03:23 PM
ger21's Avatar
You can download both TurboCNC and Mach2 and try them out for free. Either one should work fine for you. For TurboCNC, make sure you join the Yahoo group and download the Hot Fixes located in the files section there. Mach2's demo is limitedd to 1000 lines of gcode.
Old 03-06-2005, 03:23 PM
debogus's Avatar
debogus is on a distinguished road
Me too
I'm also in the same prediciment.
I have just completed a smallish cnc router.(18x10x2 /dremel spindel)
Im in the process of learning mach2 which is the control software I will probally purchase.
Next is the cam software whats the opinion on meshcam vs sheetcam?
What I can figure out so far is that sheetcam will follow lines and meshcam runs a zigzag pattern folowing the Z.
I intend to cut out letters for signs and also make plaques with a occational model parts( balsa or ?)here and there.
Which one will go farther for me or is there another option ?(cheaply)
Dave
Old 03-06-2005, 06:07 PM
ger21's Avatar
Like you said, they are for 2 entirely different things. If your cutting out parts, then you want to use SheetCAM. If you want to carve 3D shapes (or photos), then you would use MeshCAM.
Old 03-06-2005, 06:09 PM
ger21's Avatar
Neither one of these will create the drawings or models, by the way. SheetCAM takes 2D .dxf files, and MeshCAM reads 3D dxf and .stl files. You'll need a CAD package for either one. Before you go with SheetCAM, Mach2 has basic 2D .dxf conversion built in, or you can try ACE converter for free. http://www.dakeng.com
Old 03-07-2005, 09:52 PM
debogus's Avatar
Yep thats what I thought .
I have Flexi sign for my vinyl plotter it outputs dxf and I just picked up design cad 3d max.I should be set then.
Dave
parametric programming Karl_T CamSoft Products 21 05-24-2005 02:58 PM
Bridgeport Eztrack Series II -Ferror Program yuso Bridgeport and Hardinge Mills 2 05-23-2005 12:44 PM
How to cut multiple parts (loop a program) Bird_E Mach Software (ArtSoft software) 6 05-13-2005 03:16 PM
feeds and speeds program Kees Soeters General Metalwork Discussion 3 05-12-2005 12:32 PM
A few honest questions HuFlungDung CamSoft Products 8 06-15-2004 06:24 PM
