Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 05-31-2009, 05:48 PM
gaanes is on a distinguished road
3D dxf to g code converter
I used to be a happy user ogf ONeCNC til I lost the USB key and they demanded 4K to buy an entire new seat! Forget them- I bang most of my simple files out in notepad- drilling, mortices, straight moves. But I need something that will take a dxf file of a surface I draw in Cadkey, make lots of planes at the stepover increments and intersect the planes and surface for a quick and accurate toolpath), then can send a dxf file out. All I need is something to read the dxf and output G01 moves in X, Y and Z, all one line. Don't need coolant, Mcodes, all that fancy stuff.
I can't seem to find anything free or cheap which does all three axes. Help? Seems like it should be a cinch to write up.
Old 05-31-2009, 05:54 PM
ger21's Avatar
If you can export in as an .stl file, then try Freemill. www.cncportal.com
Old 05-31-2009, 11:10 PM
Has to be dxf, stl or vrml won't work
On trying that it seems that stl and vrml files need polygons or some sort of face, the files I am using consist of lines or polylines, occasionally arcs. In other words the geometry is only basic line/arc entities which I need to generate g code and coords for. I attached the dxf file
Old 06-01-2009, 12:12 AM
Switcher's Avatar
Moderator
Switcher is on a distinguished road
The dxf didn't upload...
Free DXF Files - Vectorink.com - myDXF.blogspot.com
Old 06-01-2009, 12:50 AM
DXF file attached?
Here is a retry of the file
Old 06-01-2009, 06:34 AM
yohudi is on a distinguished road
Hi there,
from what you say you effectively want to gcode a .DXF toolpath that has nodes distributed through 3 dimensions.
CamBam or gmax/CNC_Toolkit can generate gcode for this kind of .DXF
EDIT: See the image below for your file loaded in CamBam FREE Beta...
Hope this helps
Danny
What one man can do another man can do..
BitMaps to Models, 3D2Relief, tutorials and FREE CNC Software http://cnc4free.org
Old 06-01-2009, 08:11 AM
ger21's Avatar
I have an AutoCAD macro that'll work for 3D polylines, but not arcs. But you'd need AutoCAD 2002 or newer to use it.
eps to dxf converter studysession Autodesk Software (Autocad, Inventor etc) 9 05-25-2009 05:32 AM
Looking for a .dxf to G-Code converter... sciontim OpenSource Software 6 06-03-2008 12:30 PM
suitable g- code converter software for Mitsubishi MT Developer? 19darren84 G-Code Programing 0 04-05-2007 09:41 PM
help CAD CAM converter kiethnt General CAM Discussion 2 03-24-2007 09:29 AM
Ace Converter G-code Question ljoe1969 Yeager Automation 3 01-22-2004 11:18 AM
