Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 05-09-2009, 02:50 AM
subatomic is on a distinguished road
raster (full heightmap) to vector, recommendations
I have 2 goals, and maybe this takes 2 softwares, i don't know.
1.) hand drawn PCBs - where the tool would convert the 2-color bitmap to vectors that go around the contours of the PCB traces - out a certain distance to account for the engraver size... (something like wintopo pro's edge detection (simple) mode, except it'd need the ability to make the gcode lines 1/2 tool size away from the traces to preserve the trace thickness)... I don't want to do scanlines - too inefficient. too slow.
2.) 3D milling (heightfield 256 levels of grey), user specifies width/height/depth. makes efficient contours instead of running scanline by scanline over areas it doesn't need to cut, and great if it took multiple passes for milling down into thick/hard material - you could tell it how many layers to remove incrementally, and the thickness of each layer to remove... extra cool would be options for roughing pass and finishing pass, smoothing of the final vectors (cause pixels are blocky), etc...
free or at least trialware would be nice.
(sorry if this is slightly similar to the other guy's post, but i think this is more specific...)
edit1: looks like I can export vectors from photoshop. magic wand, select something, Alt-Windows, Go to paths, Click on icon at bottom that looks like a spline editor, path made from selection boundary, export paths to adobe Illustrator. in illustrator, export to DXF... import dxf into cambam then set up machining.....
edit2: looks like cambam also has a heightmap importer... though it doesn't do efficient contours, rather it does the scan line by line method...
Raster to vector lez Printing, Scanners, Vinyl cutting and Plotters 4 01-06-2007 10:54 PM
Raster To Vector (R2V) tknief CNCzone Club House 2 09-28-2006 10:46 AM
OneCnc Raster to Vector partsman OneCNC 1 01-24-2006 12:38 PM
Raster to Vector problems kdoney General CAM Discussion 4 01-17-2005 07:31 PM
raster to vector teilhardo General CAM Discussion 9 05-05-2004 08:56 AM
