Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 03-16-2009, 06:41 AM
ghedo is on a distinguished road
from dwg to dxf to stl to gcode: too many steps?
ok,
i'm a complete noob trying to understand and study before taking decisions.
I don't know if this is the right place to post this thread, this forum is so deep of informations that searching a particular item becomes a hard work.
There must be something wrong in the way I design 3D objects.
Design a rectangle in progecad, extrude, ok, is a cube, save it in acad12 dxf ascii format. Open it in LazyCam, doesn't work, no 3rd dimension.
If I open the dxf in AceConverter and convert, it always writes the same lines...
If I open dxf in MeshCam it says "there are no polygons, be sure the file was created using 3d faces"....
BUT I Open it with VisualMill, ok, I can see it, save in STL format. Open it in MeshCam, ok, post gcode, open it in MAch3, I can see the path and the 3rd dimension...
Things don't change if I design a solid, neither if I do it in Autocad.
There is something I'm doing wrong, maybe is due to the evaluation versions? or what?
thanks
Old 03-16-2009, 08:05 AM
ger21's Avatar
Can Progecad export an .stl? V12 .dxf doesn't support solids, and neither LazyCAM nor ACE will work with a 3D .dxf.
You're trying to use different programs that require different formats.
For LazyCAM and ACE, you would just draw a 2D rectangle. No extrusions, they won't work.
For MeshCAM, with a 3d Solid Cube, in AutoCAD, you can export as an .stl file under File>Export.
You can't save a solid as a .dxf in AutoCAD and get it to work in MeshCAM.
I have to assume that Progecad is basically the same as AutoCAD.
Old 03-16-2009, 08:52 AM
yohudi is on a distinguished road
Originally Posted by ghedo View Post
ok,
thanks
From your description It sounds as if your export to .DXF ascii format is either only comprised of nodes and connecting lines.... or if the 3D faces are present they may have 'face normals' facing the wong way. Put simply this just means the object could be inside out.
Some coding applications are unaffected by the orientation of 3D faces but some will not see the faces if they have 'flipped normals'.
An easy way to check this is to use a FREE utility like MESHlab to view your stl file. If the face normals are flipped, MESHLab can correct this problem.
There's a link to MESHlab in the 'Essentials' area at http://cnc4free.org
hope this helps
Danny (aka Yohudi)
What one man can do another man can do..
BitMaps to Models, 3D2Relief, tutorials and FREE CNC Software http://cnc4free.org
Tags
dxf to g-code
51,200 steps? dondeaida Stepper Motors and Drives 5 05-26-2007 06:15 AM
Steps from IGS to Gcode bill south General CAM Discussion 0 02-08-2006 03:24 PM
Full Steps -vs- Micro Steps DJB282000 General Electronics Discussion 10 12-28-2005 11:25 PM
I have a problem with my gcode or my conversion to gcode , everything is tiny? NickLatech G-Code Programing 0 03-10-2005 12:46 PM
gcode to gcode converter july_favre General CAM Discussion 4 05-24-2004 06:51 PM
