Results 1 to 3 of 3
Thread: Can you resize in Freemill?
    Registered teamtexas's Avatar
    Aug 2007
    I have a plm that I need to resize before I can run it with mach 3. Can I resize it using Freemill? If so, how?
    Dan
    Mar 2003
    Shelby Twp, MI....USA
    It doesn't look like it.
    Jan 2005
    After you get it into Mach you can resize it (sort of) by using the scale function located to the right of the DRO on program run screen. After setting the scale you can switch to toolpath screen hit the regenerate the toolpath button then look at the program extreme display to calculate the fit.
    “ In questions of power, let no more be heard of confidence in man, but bind him down from mischief by the chains of the Constitution.” Thomas Jefferson
  1. FreeMill
    By CNCadmin in forum Visual Mill
    Last Post: 07-28-2011, 03:11 PM
  2. Does Freemill output to Mach 3?
    By teamtexas in forum General CAM Discussion
    Last Post: 09-25-2009, 07:33 AM
  3. RESIZE FUNCTION ??
    By nelZ in forum CamSoft Products
    Last Post: 08-19-2008, 12:14 PM
  4. Cant Resize Dialogue Box
    By Jedi in forum Mastercam
    Last Post: 02-28-2007, 05:19 PM
  5. Resize images
    By coolman in forum Forum Questions or Problems
    Last Post: 12-24-2004, 11:06 AM
