Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 02-01-2009, 06:49 PM
Wolfesmetalfab is on a distinguished road
Corel to Autcad Text trimming
I am having troubles drawing up a sign using ovals and text in corel, and then saving as dxf or dwg and opening in autocad to trim out the lines needed to allow the parts to stay together when cutting, but I am having problems with the trimming. Some letters trim just fine to the oval outline, but others, it deletes half the letter!!!??? Whats going on, anyone have a fix?
Old 02-16-2009, 03:54 PM
BUD B is on a distinguished road
Once you bring in the .dxf file in to autocad go to the express menu then text then explode text click on this then window the text this will explode the text then use the explode comand and window the text agian then hit enter
now you can trim extend or add lines.must have autocad ver2007-2008-2009 There is a express menus for older ver from the internet look for express menus.
Old 02-16-2009, 05:21 PM
ger21's Avatar
If the text from Corel is made up of splines, that could be the problem. I've seen similar occurences when trimming splines. Unfortunately, I don't really have an answer. If they are splines, you could try a spline to polyline conversion lisp and convert to polylines before trimming.
Old 02-17-2009, 12:47 PM
jemmyell is on a distinguished road
Try the DXFTool
Try the DXFTool for CorelDRAW. It is currently sold by CandCNC.com
-James
James Leonard - www.DragonCNC.com - www.LeonardCNCSoftware.com - www.CorelDRAWCadCam.com - www.LeonardMusicalInstruments.com
Old 02-18-2009, 07:37 PM
If the text from Corel is made up of splines,In autocad save the file as wmf this will explode the splines.
Need Help!- Problems exporting Corel text files as DXF CustomConcepts Printing, Scanners, Vinyl cutting and Plotters 3 10-21-2008 02:24 PM
Need A Quote- router trimming snocutt Employment Opportunity 0 08-21-2008 01:46 PM
Trimming in bobcad Parameter BobCad-Cam 2 12-30-2005 04:07 PM
DXF export from Corel - Text cutting maxxgraphix G-Code Programing 3 03-23-2005 10:12 PM
Autcad UCS trick wjbzone Autodesk Software (Autocad, Inventor etc) 1 02-24-2005 10:20 AM
