| General CAM Discussion Discuss CAD/CAM software and Design software methods here! |
| G-Code Transfer Hello all, A good mate of mine picked up a Hercus Computurn CNC lathe which was being put into a dumpster bin from an old Tech School. It has an ANCA 2000 controler that I can get operating by typing in G-Code by hand. Everything seems to work. Z axis, X axis and spindle all respond to code. Typing by hand is very tedious. Are there any programes that are free that can be used to transfer CAM gererated G-Code from my PC into the controller. By way of example I found DNC which is around $300.00 AU. If you have an info or links to site I can download a free transfer program it would be greatly appreciated. Is there anyone else out there with this type of lathe or controller, drop a line. Thanks Cam |
| Free DNC program Hello Cam, Here is a link to the CAMBack Easy DNC program on the EVO-Solutions website: http://www.evo-solutions.com/english/downloadservice/ I am also an authorized reseller for this company so let me know if you decide to buy. I hope this helps you out somehow. Regards,
__________________ Regards, Wes |
| You should be able to send Gcode to your controller using any terminal program. I use the windows hyperterminal and select to send a file. You will need to set the RS232 parameters to suit the controller. Try 9600 baud No parity 1 stop bit. If it like my controller, To set the controller up to recieve, choose "8" from the first menu then "o" then "3" select a program number or file name. Then run hyperterminal and send the G code. After the G code has been sent you will need to set the program number or name as the Active file using the "s" command. |
| Code Transfer - Bosch CC100 | martindugdale | Commercial CNC Wood Routers | 8 | 09-20-2011 06:23 AM |
| CncGcoder G-code transfer is NOT DNC! | widgitmaster | Polls | 3 | 05-03-2007 02:52 PM |
| Trouble with DXF to G Code Transfer | mlapacz | SheetCam | 8 | 03-04-2007 01:25 AM |
| how to transfer? | hop | General CNC (Mill and Lathe) Control Software (NC) | 0 | 06-15-2006 12:35 AM |
| file transfer | axis overtravel | Fadal | 13 | 01-26-2006 10:55 PM |
