Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 10-23-2008, 07:57 PM
drafting101 is on a distinguished road
Question dxf to dgn converter
I need a program (fast) that will convert a .dxf file to a .dng file. Any ideas?
Brian
Old 10-23-2008, 08:37 PM
harley4ever is on a distinguished road
Not sure what a .dng file is. Do you mean .dwg?
Old 10-23-2008, 08:47 PM
No a .dng file. It is the file type that our EDM shop uses. They use Bobcad, I don't have Bobcad at home and I need to convert some shapes to send to them.
Brian
Old 10-23-2008, 08:51 PM
If that is bobcraps own extension, I would assume you would need to export the file from within bobcrap. I am not sure that there is a system out there that will do that. If its a dxf, dwg, iges, step, or something of that statue, it would be simple.
eps to dxf converter studysession Autodesk Software (Autocad, Inventor etc) 9 05-25-2009 06:32 AM
USB to Parallel converter tee2 Mach Software (ArtSoft software) 1 01-15-2008 05:30 PM
help CAD CAM converter kiethnt General CAM Discussion 2 03-24-2007 10:29 AM
DC/DC converter Kan Mazak, Mitsubishi, Mazatrol 5 01-22-2006 04:13 AM
VB File converter MetLHead Visual Basic 4 06-20-2005 10:16 PM
