| General CAM Discussion Discuss CAD/CAM software and Design software methods here! |
| Hi everyone! I need some advice regarding some CAM software which will permit me to import DXF files ( and / or DWG) and which will operative with an old Heidenhain TNC 155 control on a Bridgeport Interact 1 MKII mill....? I currently use the Heidenhain conversational mode of programming and not the G code but as I understand, the TNC155 is also G code compatible. I would really like to be able to speed the process up a little as a lot of the work I'm getting now is small batch size and therefore the programming time(especially when stock removal and multi rad arcs are involved) contributes to a large proportion of the total job time. In actual fact, even a means of off-machine programming would be great so as I can prog. the next item whilst the mill is still running with the current item. Any advice would be very gratefully received ![]() Duncs. |
| Hello Duncs, Have a look at Dolphin PartMaster - www.dolphin.gb.com We have a range of products to suit your needs, and have post-processors that output Heidenhain plain language - L X50, Y50, R M etc. You can download a trial system from the website or call us on 01563 543989 for more info. Best Regards Andre |
| Interact Bosch servo drives for cheap!!!!!! | Interact77 | Bridgeport and Hardinge Mills | 5 | 02-01-2010 06:29 PM |
| Erratic behavior from Bridgeport Series 1 Mk2 with TNC155 | dbcooper99 | Bridgeport and Hardinge Mills | 14 | 01-16-2008 12:14 PM |
| Bridgeport TNC155 with EMC2? | dbcooper99 | LinuxCNC (formerly EMC2) | 0 | 12-15-2007 03:34 PM |
| Interact 1 MKII 4th axis problem....? | DuncanRitchie | Bridgeport and Hardinge Mills | 1 | 08-22-2006 10:05 PM |
| Bridgeport Interact 1 MkII problem | sparsrus | Bridgeport and Hardinge Mills | 13 | 05-02-2006 04:53 PM |
