| General CAM Discussion Discuss CAD/CAM software and Design software methods here! |
#13
#14
| I used NX. I imported your image as a raster image, scaled it to 600mm wide, then drew lines & curves over the letters. Then I create a solid block, and extruded the lines & curves, subtracting them from the body. The rest was simple NC machining using a 9mm & 1.5mm tool. Then I just modified a 3 axis postprocessor to output the format from your example. It looks like your Xilog system uses left hand rule (+Y points down), thus the reason it's inverted. Now I understand the DY-___ from the Y values. You should be able to do a Find/Replace Y= / Y=DY- if you want to invert them. Here are all 3 files: http://home.comcast.net/~bridge161/h..._rough_9mm.ptp http://home.comcast.net/~bridge161/h...ners_1.5mm.ptp http://home.comcast.net/~bridge161/h...file_1.5mm.ptp
__________________ "Of course, that's just my opinion. I could be wrong!" T Briggs (CAM dude) - Siemens PLM Software |
#15
can you give me a full name of the software because I want to download this soft. I have another question, can you do a simple drawing with NX software? p.s. this flag http://bardhihaliti.com/blog/wp-cont...-of-kosova.jpg in the panel 600x600 mm I will know you for the rezults thnx |
#16
| Glad to be of help. You can find information on Siemens PLM Software NX (formerly Unigraphics) here: http://www.plm.automation.siemens.co...s/products/nx/
