Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 07-01-2008, 05:07 AM
fitzpatrick2362 is on a distinguished road
Maho Postprocessor for Edgecam
I am currently using Edgecam CAD/CAM software.
I am having trouble getting the correct output on my Maho Post processor.
It is a 3 axis Vertical Maching Centre using Philips control.
Common problems are that Y axis is Z and Z is Y, X+ is X-and various others.
Does anyone have experience with this control or even better does anyone have this post.
Old 07-16-2008, 02:27 AM
smoregrava's Avatar
smoregrava is on a distinguished road
Hi I'm working on a post for this. I belive that I have this finnished during this summer. I resently bougth a Maho mh500 c 432 controller and I have made the connection to my computer. This works nice. I would love to dripfeed but seems that this is not possible on my control early maho 432 control. I have buildt some postprosessors at my work and have started the prosess with the maho post. I have not tested anything yet but the problem that Y is Z and so on seems to be solved. I will share the post as soon I have something I have tested.
Old 07-16-2008, 06:31 AM
That would be great.
Any help would be appreciated.
Old 07-23-2008, 05:31 PM
smoregrava's Avatar
I have now done the first sucsessful testing with my new post. It now works nice in profiles Axes and radiuses Works. Needs to test some drilling and some 3D motions. I send the post to you as fast I have tested this.
I was fun to se the machine moving along the path I programed in Edge Cam.
Old 07-24-2008, 06:55 AM
Good stuff.
I have not had time to even look at the post lately.
Old 08-10-2008, 08:57 AM
parveenk78 is on a distinguished road
dear sir.
i have one maho50 horizontal machining centre with philips432 cnc control but i can't download the programs to my pc i mean i need the wire detail for RS232 communication if you have then please send it to me at my yahoo i d it's parveenk78@yahoo.com i will b thankfull for the same
thax
Parveen from india
Old 08-10-2008, 02:49 PM
smoregrava's Avatar
Yes I have what you need to connect and download programs. I wrote this in another thread here at CNCZone
http://www.cnczone.com/forums/showth...t=38719&page=5
But I repeat it here.
I made my Maho 432 to talked to my computer(DNC). I have made a DB9 to DB25 full handshake cable (Like in the picture). And i used Hypertermial to transfere the programs. easy and seems to work nice
Here is how I did it if anyone wants to know:
First I checked Machine constants
Nr 115 =1 means 2 as stop bit (=0 means 1 is stop bit)
Nr 116 Input Baudrate and
Nr 117 output baudrate. In my case baudrate was set to 300, but I found in some papers that they had used 4800 before on my machine so I will change this as soon as possible.
Then I opened Hyperterminal (Is in windows under comunication)
I used this parameters
connect to Com1
Baudrate= 300
Data bits= 7
Parity= Equal
stop bits= 2
Flow controll Hardware
Send CR at line end
Local ecco
Then I go to the controll and press
"MANUAL"
"PART PROG"
I selected ALL MEMORY
press "MEM LOCK"
"DATA INPUT"
Then I used a simple program as a test
% PM
N9008
N1 G1 X20 F500
N2 G1 Y20
N3 M30
I marked the text/program above and rigth click in Hyper terminal window and choose "Paste to Host"
When all lines was sent I have to press
"CTRL+D" on the computer. Then the program is in the controll.
I Actually don't anderstand why I have to press ctrl+D. But its works
I also loaded programs and tool table out of the machine to the computer.
Hope this helps
Old 08-11-2008, 12:00 AM
Dear sir..
Thax a lot for helping me i will try the same but i m not able to read this format of wire layout (connection detail for cable) coz it's too small ..can you send it to me with any inlarge view so that i can read the same please convert it in to ms word if u can ..
it will be gret help of mine..
Thax & Regards
Parveen
Old 08-11-2008, 01:21 AM
smoregrava's Avatar
Ok try this. I made the full handshake DB9-DB25. I have this PDF At second page you find the cable info
Old 08-11-2008, 01:53 AM
thax a lot for helping me i will try the same and will reply to you.
Thax Again
Take care
Parveen
  #11   Ban this user!
Old 08-13-2008, 12:58 AM
Dear Sir,
i tried the way you told me about but i m not able to download the programe from machine to my pc and not able to upload the programe from my pc to machine basicly we bought this second hand machine and now after a long time it's start we did not run this machine i don;t know about the history of this machine may be there is any other problm with system or any kind of cable i mean to say internal problm in the control..
what do you think about this matter..
i m really thankful of you for spending some time on me if you can guide me more you have any other guidence about this matter then i will b thank full for this ..
Thax & Regards
Parveen from india
  #12   Ban this user!
Old 08-13-2008, 04:50 AM
smoregrava's Avatar
Are you able to start you machine and use? The machine has to be in manual and the Hyrdaulics has to be active when you send and recive data. This means that the machine can't have active alarms before you transmitt data.
If the machine does start check this thread for more info on startup http://www.cnczone.com/forums/showth...t=38719&page=5
Do you get an alarm when you transmitt data?
Postprocessor maho 700C Gerwin Deckel, Maho, Aciera, Abene Mills 2 10-12-2008 02:43 PM
Axa edgecam postprocessor arendal EdgeCam 0 06-17-2008 05:22 AM
Need Help!- Axa edgecam postprocessor arendal Post Processor Files 0 06-17-2008 02:40 AM
Postprocessor for EdgeCAM prochaska General CNC (Mill and Lathe) Control Software (NC) 7 11-22-2006 04:31 AM
Help needed with Edgecam postprocessor for Kosy A5 Jogge General CNC (Mill and Lathe) Control Software (NC) 1 03-22-2006 04:54 AM
