| General CAM Discussion Discuss CAD/CAM software and Design software methods here! |
I have an AXYZ 5010 ATC Table since 2004. I use Toolpath v2.8.03 to 3D engrave letters for routed Cedar signs My problem is that the cutter is ignoring the speed settings and moving rapidly on some of the vectors, this is a problem when I try to engrave into cedar as the rapid movement causes the cedar to chip. I typically run at 22 inches and 22000 rpm. I have been using the 3D engrave utility in Toolpath which is where I discovered the problem. 1 in 10 signs chips to the point where I have to remake it. 1 out of 3 will require filling or repair work. I downloaded the demo file from Vectric and their sample file does the same thing. I would appreciate any help or ideas on how to solve this problem. |
| Tags |
| 3d engrave, axyz |
| Need Help!- Feed rate Ovverride also Increases rapid rate. | Korellibopper | Machines running Mach Software | 1 | 01-30-2008 05:37 PM |
| Feed Rate and Spindle Rate for this cut? | DroopyPawn | General Metalwork Discussion | 20 | 11-21-2007 11:12 PM |
| Feed Rate? | bearwen | GRZ Software- MeshCAM | 3 | 04-26-2006 04:52 PM |
| C & Z Feed rate | rfstar | G-Code Programing | 7 | 06-22-2005 12:38 AM |
| How can I up my feed rate ? | ynneb | DIY-CNC Router Table Machines | 7 | 07-12-2004 09:40 PM |
