Results 1 to 5 of 5
Thread: Can someone suggest a CAD/CAM?
    Mar 2007
    I'm building a cnc router with the purpose of making speaker baffles. Real simple stuff (beveled holes usually). Seems to me that it's kind of wasteful to buy a sophisticated cad/cam package, not to mention the time it takes to learn the software. If any one have a suggestion for a cad/cam package that works with Mach 3 I would really appreciate your opinion.
    Registered metalworkz's Avatar
    Oct 2006
    Modesto, CA U.S.A.
    Hi Jimluu,
    If you are only going to do 2D parts with the router the Cut2D program from Vectric is priced very reasonably, posts toolpaths very quickly with a great simulator included for around $150 I think, but it does not include a CAD program. If you need both CAD and CAM, Dolphin CAD/CAM USA has many packages for different needs at very reasonable prices and you can find their authorized reseller on eBay also. There are so many programs available so it may be good to download some demo versions to see if what they offer will work for you and choose the one you like best. I'm sure someone else will probably suggest other choices for you. Good luck and I hope you find something that works good for you!
    Regards,
    Regards,
    Wes
    Registered ImanCarrot's Avatar
    Nov 2005
    UK
    Dolphin CAM is very easy to use and intuitive. I can recommend it. The support here in the forum and from the actual retail office is superb. I have no connection with Dolphin apart from being a very satisfied user.
    I love deadlines- I like the whooshing sound they make as they fly by.
    Jan 2007
    I concur with ImanCarrot. I use dolphin as well and it is very robust and easy to use.
    Wade
    Gold Member dertsap's Avatar
    Oct 2005
    canada
    ive got dolphin as well and it is a pretty decent program ,i'm sure if you talk with Rodney from Dolphin US , he'll be able to put together a package that will suit your needs .
    if you can t afford or justify the cost of a decent cad/cam system , there are a number of freewares on web that with a little work can post out a decent program
    A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
    http://microcarve.microcarve.biz/
    1. Suggest a CAD package for me?
      By JayH1119 in forum General CAM Discussion
      Last Post: 01-04-2008, 09:51 AM
    2. suggest a unit
      By Sonicmook56 in forum CNC Machining Centers
      Last Post: 08-27-2007, 11:57 PM
    3. Suggest a VFD
      By bcromwell in forum Phase Converters and VFD
      Last Post: 04-20-2007, 11:11 PM
    4. Suggest some software! Please
      By disinformation in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 01-13-2006, 04:16 AM
    5. Can any suggest
      By CNCadmin in forum CNC Wire Foam Cutter Machines
      Last Post: 04-06-2004, 11:23 PM
