Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 04-18-2008, 08:42 AM
Tempus is on a distinguished road
convert .jpg to gibbs or.igs
I am working on a side project at work. We use GibbsCAM for software, and I'd like to take a .jpg file, convert it to something I can import into Gibbs, and etch the image onto a steel plate. I am fine once I get it into Gibbs, but have had no luck finding software that would let me convert a line drawing .jpg file to something like an .igs file.
Any help would be appreciated,
Thx
Old 04-20-2008, 10:21 PM
metalworkz's Avatar
metalworkz is on a distinguished road
There are some raster to vector converters available that will enable you to load the .jpg or .bmp etc. and then after you vectorize it you will be able to save vectors as a .dxf which I would think you could easily import into GibbsCAM. Wintopo ( www.wintopo.com ) has a freeware version that will probably work but there are other raster to vector conversion programs available that will do the same. Magic Tracer is fairly cheap at around $49 and I think they have a trial version that is good for something like 11 uses. You can Google search and find more of the same. Hope this helps you out somehow.
Regards,
Regards,
Wes
Old 04-21-2008, 04:13 PM
thx much
Life, Liberty, and the pursuit of those that threaten it...
Old 04-21-2008, 04:28 PM
nine6 is on a distinguished road
Photoshop or Illustrator can also convert from raster to vector. Pretty sure Illustrator can export to .dxf also.
Help using CS in Gibbs v7 microdot GibbsCAM 4 07-02-2010 03:00 PM
gibbs cam ultrapeter General CAM Discussion 8 10-09-2008 08:28 PM
Newbie- convert pic to Gibbs Tempus General Jewelry Design Software 4 07-01-2008 10:10 AM
Gibbs Jonathan3520 Shopmaster/Shoptask 0 10-14-2006 07:47 PM
V-GIBBS v8.0.12 jybute GibbsCAM 5 09-20-2006 07:32 AM
