Results 1 to 6 of 6
Thread: Scan into CAD program recomendations??
    Registered metalworkz's Avatar
    Oct 2006
    Modesto, CA U.S.A.
    I was wondering if anyone here has found a good program to use for scanning printed or faxed drawings into a usable image to use in CAD for program generation etc. There has to be a better way to take printed drawings back into CAD for programming parts than to redraw it all the time? I have found a program called Scan2CAD with a free 7 day trial but thought I would see if someone here has found a good solution to this problem before I try it. Thanks in advance for any help you can provide!!
    Regards,
    Regards,
    Wes
    Gold Member High Seas's Avatar
    Sep 2003
    Malaysia/Australia/NZ/USA
    I played with it a bit a few years back - looks more advanced than before. But you piqued my interest and I found this:
    http://www.cadtool.net/image2cad.htm
    they say, "Image2CAD is a handy tool for converting raster image to DXF file, especially useful for crystal, metal engraving or title block's logo importing."
    See it going for $99 - a bit cheaper.
    Are you wanting to go from scanned to CAM? And not CAD? What about using a vectorizer http://vectormagic.com/ then generate G code with some other programs or start with a R2V? There are several programs to do that - all have some limits though,
    http://pcwin.com/Multimedia___Design/R2V/index.htm
    Rasterfratz (free trial as I recall) http://www.imsrv.com/rasterfratz/ , etc
    Hope thats helpful!
    Jim
    Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
    Banned
    Jan 2006
    Seattle
    What I do is scan the image and save it as a JPEG. I use Solidworks to create a drawing. Then under Tools select Sketch Tools then Sketch Picture. When you load the pic you can Scale, Rotate, and Translate it any way you want. Now you can very accuratly create geometry that copies the pictures geometry.
    Oct 2006
    Modesto, CA U.S.A.
    Thanks for links, ideas and tips. I will give them a try and I'm sure if you had good results with these methods they will help me also. The help is much appreciated!!
    Regards,
    Regards,
    Wes
    Apr 2008
    soain
    another r2v I use somtimes is Algolab Rasterto Vector (google), needs tiff b/w. First I work the image with Gimp to simplify curves an so on, then I vectorize and save to a dxf file.
    toni
    Mar 2007
    I think bobArt does that.
    1. importing large scan into v21
      By gromit68 in forum BobCad-Cam
      Last Post: 07-05-2007, 03:47 AM
    2. Scan to G-code
      By 9lrac9 in forum Mach Software (ArtSoft software)
      Last Post: 06-22-2007, 10:41 PM
    3. Model or Scan?
      By robinsoncr in forum Rhino 3D
      Last Post: 02-27-2007, 10:54 AM
    4. i need someone to laser scan a part for me
      By camarogod98 in forum Digitizing and Laser Digitizing
      Last Post: 02-11-2007, 06:56 PM
    5. Scan-Import Shapes
      By edwardpic in forum General Waterjet
      Last Post: 10-04-2006, 12:41 PM
