Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 04-09-2008, 07:16 AM
AleksC is on a distinguished road
Common Serial CAM protocol?
I'm currently working on developing a serial-interfaced CNC controller based on the Arduino platform. I'm trying to overcome the problems of non-realtime operating systems and future-proof communications. The arduino platform fixes both of these, since it uses USB, and has a fairly powerful microcontroller that can keep the timing for everything sorted out. That way the OS doesn't have to stress out trying to bitbang a parallel port (which you may or may not have!).
My question is this: is there a common serial protocol for CAM software to talk to CNc controllers? I've been messing with KCAM, and I see it has a serial interface option, to work with the serial controller kellyware sells. The current plan is to reverse-engineer the KCAM serial protocol to create a compatible firmware for the arduino. Of course, if someone wanted to create an alternative firmware that worked with other software, that'd be great, but I'd rather code the firmware for a protocol that worked across a wide variety of CAM software.
Tags
arduino, diy, opensource, serial
XY2-100 protocol coyoteboy General CNC (Mill and Lathe) Control Software (NC) 12 12-02-2011 07:41 AM
adding jabber as IM protocol in User CP? aspenelm Suggestions for the CNCzone.com site. 1 01-08-2007 12:37 PM
Mazatrol format and protocol checksome Mazak, Mitsubishi, Mazatrol 1 06-21-2006 08:41 PM
haas indexer serial protocol ? pit202 Haas Mills 0 02-28-2006 12:08 PM
Boss5 Procomm Settings/Protocol jeaBOSS5 Bridgeport and Hardinge Mills 5 08-18-2005 09:58 PM
