Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 03-24-2008, 05:21 AM
jeffmorris is on a distinguished road
Sign making software?
I found out that the VCarve software costs $600. Mach3 software costs $160. At the woodworking shop at the program for mentally handicapped people, we make different kinds of signs for customers. We make four kinds of signs:
1. Cut out each letter or number, and glue them to base or board.
2. Cut out spaces between letters/numbers on a piece of board. The letters/numbers are held by the frame at the top and bottom.
3. Cut out letters/numbers on a piece of board that are held to the stripe at the bottom.
4. Crave letters/numbers on a piece of board.
Old 03-24-2008, 05:38 AM
Switcher's Avatar
Moderator
Switcher is on a distinguished road
Are you asking If it is possible for Vcarve to do the 4 things in your list?
If so, yes Vcarve will cut everything in your list & way more.
Every DXF file in my Blog was created with Vcarve Pro.
If your asking If both do the same things, then the answer is no.
Mach3 = CNC Machine Control
Vcarve Pro = Creates the toolpath to run on the cnc control (Mach3, etc...).
Free DXF Files - Vectorink.com - myDXF.blogspot.com
Old 03-24-2008, 06:05 AM
I don't know who'll pay for the VCarve software. I thought that there's either freeware or low-cost sign-making software
Old 03-24-2008, 07:51 AM
yohudi is on a distinguished road
Hi there,
There are some FREE options to create gcode for carving and cutting letters etc... not specific to sign-making but you might have some success with them...
visit the website at the URL in my signature....
I would recommend that you plan on buying mach control software.. there are some free control applications.. but to be honest it's not worth the risk to your machine.. Mach software is a tried and tested solution...
Hope this helps
Danny
What one man can do another man can do..
BitMaps to Models, 3D2Relief, tutorials and FREE CNC Software http://cnc4free.org
Old 03-24-2008, 08:52 PM
I found out that LazyCam can create text but I had problems creating text in LazyCam and loading the file generated by LazyCam into Mach 3.
Old 03-25-2008, 03:31 AM
I don't really use LazyCam myself. Most people end up using the Mach part of the package to control their machine. Then look to generate the code to run in Mach using a wide range of either commercial or FREE software.
Which you use depends really on a few things. What you want to make, how quick you need to be able to make it, your level of experience, how much you have to spend and suchlike.
Your post asked about free software.. which is why I directed you to the website I made about FREE CNC software...You may find a solution.. you may not... depends on your own unique circumstances.
Danny..
Old 03-25-2008, 05:23 AM
Danny, I checked out your website but I can't find info specific to sign making. I already have IntelliCAD program that's compatible with AutoCAD files but I can't convert text to polylines. I'm not sure if 3D Canvas can create 3D letters and numbers.
Old 03-25-2008, 07:20 AM
Trell is on a distinguished road
Smile Cut 2D
VCrave Pro is the best for cutting just about anything
but the 2D Cut for $149 is not bad and you can started cutting rightaway
When I started this hobby, I did not cut anything that would look good till I downloaded VCarve.
Download 2D Cut demo and I think you will be cutting in about an hour if you have your CNC up and running This is the eazyest software I could find
Works kind of like some photo software
Click and Drag to make it bigger or smaller
Mach 3 is the best to run your CNC just DO NOT waste your time or money with
Lazy Cam
Put your $75 into VCarve
Old 03-25-2008, 01:46 PM
I downloaded and ran the Cut2D demo. I went through a tutorial on creating a sign (nameplate for model locomotive) and I liked the program. My CNC machine isn't ready to use yet.
Old 03-25-2008, 04:30 PM
Hi Jeff,
It's true.. I tend not to say use this for this... primarily because most of the utilities can be adapted a number of ways... perhaps it's something I should start... a list of uses for each tool....
whichever way you go I hope it works out..
ttfn
Danny
  #11   Ban this user!
Old 03-26-2008, 06:08 AM
I think that Mach3 has a wizard for text engraving. Is this good or do I still need either Cut2D or V-Carve?
  #12   Ban this user!
Old 03-28-2008, 08:32 PM
Mach3 and Lazy Cam
That would be Lazy Cam (in Mach 3), Dont waste your money or time
They got me for $75 and it is hard as hell to work, VCarve is alot eazier.
We need someone to wright a program
Mix Mach3 and VCrave into one for one price
But I dont think anyone could do that because they would corner the market
and put everybody out of bussiness.
But only if they could sell it for (lets see) say $199.95
Maybe, to good to be true
but still fun to wish
Trell
SIGN Making methods? esmiller General CNC (Mill and Lathe) Control Software (NC) 8 05-23-2008 10:49 AM
Newbie- simple sign making mc-motorsports Vectric 2 03-23-2008 01:17 AM
Plasma CNC for Sign Making Robin3295 CNC Plasma and Waterjet Machines 7 04-27-2007 06:17 AM
Software for sign making? CRFultz General CNC (Mill and Lathe) Control Software (NC) 5 04-12-2005 10:25 AM
