| General CAM Discussion Discuss CAD/CAM software and Design software methods here! |
I know that in some cad systems, there is a feature called history or history tree. I have seen mention of it in cam systems, but I don't know what it is called. Would someone knowledgable in the use of such a system enlighten me as to how they work....and what they're called? What I'm looking for is an answer to the following question. If you create a toolpath with say .500" ball nose and you have all the parameters set up but have yet to post the code, then realise a .459" ballnose would be better, can I simply change the parameters for the cutter, hit a button and the software update the toolpath? No other input require other than the one change? Mike
__________________ No greater love can a man have than this, that he give his life for a friend. |
Now for the cam part. Yes, you can edit the size of the endmill and re-generate, and the toolpath will update without any other input. These analogies are very simple, and softwares will have their differences, but that's the general concept. Hope this helps
__________________ Hey, why's it going over there?!! |
| Thanks cammotion and Ger, Ger your question is what I want to know. cam got close, but I want to know if there is a history tree in cam where, as you ask, change a parameter and the result is all the following information is updated. Let me get to the crux of my questioning. Joakim from Madcam is going to put some sort of history tree within Madcam and he ask me which would be better to start the tree with.....the cutter selection or the toolpath (not his idea). I assumed that most everyone who does cam, opens the model then selects the cutter of choice, sets the tolerences etc. until the tool path is created. It seemed quite backwards to me to start with the last step, but since I have never used a tree.....I thought I had better ask! ![]() Since you are a mod, can I do a poll to ask questions about how this should be done and get the reasoning behind the thoughts? Mike
| I use Unigraphics NX 5, so this might be a scenario: Note: In NX, the list of operations in the tree will have green checkmarks next to them if they've been posted. If you change a parameter in an operation, a red circle with a slash through it will appear, meaning you have to hit the "re-generate" button. Once you re-generate, it will have a yellow "exclamation point" next to it, meaning it needs to be re-posted. Let's say I have a program for a part that consists of roughing, semi-finishing and finishing a tapered pocket. The pocket corners have 1/4" radii, and were finished with a 1/2" endmill, causing the cutter to change direction abruptly in the corners, so I want to use a 3/8" cutter to make the corners a sweeping motion. In the finishing op, I make the cutter change, and this will turn that op red, so I hit re-generate to re-calculate the toolpath, and re-post. So, in my case, the program doesn't automatically update throughout without some clicking as described above, but it is pretty quick and easy to make modifications. (There are other ways to make changes in NX, but I'll save it for a different discussion.) I'm sure that most softwares work in a similar fashion.
__________________ Hey, why's it going over there?!! Last edited by Cammotion; 03-08-2008 at 11:00 AM. Reason: Hillbilly grammar! :-D |
| Feel free to start a poll, but I think that you might only get useful info from those that have actually used madCAM, and know the way it works.
| Ger I'm not sure if you meant Madcam has this feature now or not, but if so, no it doesn't. Anyone should be able to give input since what I am asking is not tied to any specific program, but a concept. I want to know what people think would be a good way to implement this, or something akin to it. BTW I already have your input! With that said, and assuming you knew ahead of time the different changes you wanted to make, they could all be updated at once. On the other hand, if you discovered a needed change after making one, then the time would be no different anyway.....least wise the way I see it.Mike
| Terminology question | 91bird | General Metal Working Machines | 7 | 01-07-2007 12:04 PM |
| Lathe name terminology. | l u k e | General Metalwork Discussion | 7 | 12-11-2006 07:36 PM |
| CNC Terminology | gaza | Australia, New Zealand Club house | 1 | 06-26-2005 05:12 AM |
| Terminology CAD/CAM | BarneyW | General CNC (Mill and Lathe) Control Software (NC) | 1 | 04-22-2005 02:02 AM |
| A terminology question | Photon | Mechanical Calculations/Engineering Design | 8 | 04-03-2005 07:32 AM |
