Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 03-02-2008, 04:54 PM
Mr.Chips's Avatar
Gold Member
Mr.Chips is on a distinguished road
Question Tabs How and Where?
A response from Joe in his 4X4 Hybrid thread (I didn't want to hyjack that thread): "Its a feature in V-Carve Pro you can add them automatically or place them where you want and specify all the parameters of them, i.e. width and height, 3d or not."
Other than "V-Carve" what is the easiest and cheapest way to have tabs in your drawings?
Old 03-02-2008, 05:10 PM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
If you do not have a program which can insert them for you, I would draw a duplicate of the part outline on another layer in Cadd off set it 1/2 the bit dia. and manually delete the line segments to exclude the area there you want tabs i.e, ------ ------ the space being the tab and machine the line directly for your final pass, If you have say 0.75" stock, machine everything as you would normally but on the final pass on the part cutout off (machine to a depth of 0.625") leaving the final 0.125" for your tab machining.
Hope that kinda explain how i would go about it.
Joe
Old 03-02-2008, 10:03 PM
Mr.Chips's Avatar
Gold Member
Joe
Thanks Joe,
I'm new to cad drawing and I keep forgetting the value of layers. That will do it.
Old 03-04-2008, 06:27 AM
sawmiller is on a distinguished road
lazycam has tabs also, they are just harder to find
dan
Old 03-04-2008, 06:53 AM
LeeWay's Avatar
LeeWay is on a distinguished road
Just for the searching aspect of this thread, Sheet Cam also has tabs. They are very easy to use. Any size or thickness.
Lee
Old 03-04-2008, 08:08 AM
ger21's Avatar
Check Vectrics new Cut2D for $199. I didn't see it listed, but I'm assuming it has it. Check out the demo, it's basically Vcarve Pro without the V-carving.
Rhinocam and Turning/Tabs Moondog Rhinocam 4 09-23-2007 10:05 AM
Problem using tabs LongRat SheetCam 4 08-06-2006 03:39 AM
TL-1 Missing Tabs elaganis Haas Mills 2 06-19-2006 12:24 PM
Adding Tabs With MasterCam V9 mmcclain02 Mastercam 5 01-20-2006 01:53 PM
Tabs in V9 MikeA Mastercam 13 03-20-2004 05:55 PM
