Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 01-31-2008, 02:43 PM
ProDrawerCom
IQChallenged is on a distinguished road
Wacko gear backlash (or not)????
The most expedient way of asking my question is to ask you to visit my site and read the first article regarding "making some gears". Something just doesn't make sense (to me). http://projectcnc.wordpress.com/
Old 01-31-2008, 04:52 PM
ger21's Avatar
Looks like a goofy gear, but hard to say for sure without seeing the .dxf
Also, I'd recommend using a free CAD program vs Sketchup. It's very possible that Sketchup is saving the size incorrectly. I'd recommend ProgeCAD Smart.
http://www.progecad.com/compra/index...age=1&lang=eng
Old 01-31-2008, 07:23 PM
ProDrawerCom
[QUOTE=ger21;402947]Looks like a goofy gear, but hard to say for sure without seeing the .dxf
Here's the dxf straight from traceparts
Old 01-31-2008, 07:27 PM
ProDrawerCom
Looks like a goofy gear....
I'm glad to hear you say so. Some times I think I just don't look at things right.
Old 01-31-2008, 07:32 PM
ger21's Avatar
I looked at the .dxf, and it looks like your results are correct. And the diameter at the tip of the teeth is about 16.063.
Old 01-31-2008, 07:35 PM
ProDrawerCom
I've known all along that SketchUp MIGHT be throwing me some curve balls since it doesn't even pretend to be a CAD program. But you know how it is. You get used to something and hate to climb a new learning curve. But thanks for the suggestion. I'll definitely check it out.
Old 01-31-2008, 08:00 PM
ProDrawerCom
That's good news. Furthermore I downloaded a different gear and SketchUp faithfully handled it. I think it's good to establish whether the program is worthy for the CNC hobbyist as a CADlike utility. I'm still gonna look at the freebie CAD you suggested.
Basic Bevel Gear - Milling a valley for gear teeth ngr1 General CAM Discussion 10 04-05-2012 09:55 AM
Zero backlash worm gear idea. ynneb Mechanical Calculations/Engineering Design 14 07-31-2009 12:25 PM
Backlash or motor tuning problem? How do I test for backlash? Brian Queen Mach Mill 8 03-10-2008 03:35 PM
Servo idea - elimated backlash - zero backlash ! synthetiklone Linear and Rotary Motion 6 12-06-2006 01:35 PM
gear backlash phil spanner Mechanical Calculations/Engineering Design 2 09-08-2005 08:38 AM
