| General CAM Discussion Discuss CAD/CAM software and Design software methods here! |
| I tried out the Profiler - and its really - really good value. Like MACH2 it generates a raster cutting code set. I like the redo options it has and the ability to preview before loading it up. I've been writing a general review of low cost image to G-Code aps , should be posted in a few. The timing of you question is uncany! Cheers - Jim
__________________ Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it. |
| Jim, Be sure to check out the one in DeskCNC. It is probably the most capable around and includes both a unique tracing ( engraving ) style cutting (all closed shapes, no lines to nowhere) and 3D depth variations based on shades of gray within a bit map file. It's unique in that it automatically compensates for ball, bull, Vee or flat cutters, it can import most kinds of graphic image files, including frames from avi, scans direct from scanner and camera, and has built in graphics editors that permit you to adjust contrast, brightness, and to apply various filters like bump map, lens, wave, etc. It also does a 3D shaded render of the part surface, using the same tools as you specify in creating the toolpaths. Fred Smith - IMService |
| Fred - I'll do that as I have some spare time - I really liked the features in Rasterfratz for getting from an image to a DXF or G-Code. Quick and simple. I'll check out the DESCCNC after I give STL and Accutrans a whirl. Sent you a pm regarding that - over. Jim
Hello Mark & Jim, VS3D can generate G-code directly from image files with no vectorization required. In VS3D, the surface heights (Z axis) are automatically scaled directly from the gray-scale (or color) values in the imported image. VS3D also supports DXF, STL, and point clouds. In addition, VS3D excells at Virtual Sculpting by providing sophisticated tools for hammering, scraping, chiseling, ramping, smoothing, etc. VS3D supports roughing and finishing tool paths. All of the 3D tool offset calculations are performed automatically, based upon the 3D shape of the chosen cutting bit and the surface being cut. Proposed cutting passes are shown on the shaded surface display. You can see exactly what the part will look like after the roughing and finishing passes. Here is an example of a VS3D design machined in brass: http://www.designscomputed.com/vs3d/examples/index.html
__________________ Daniel Carr - President, Designs Computed, LLC |
| Read this article- http://www.cnczone.com/modules.php?s...ticle&artid=22
__________________ Thank You, Paul G Site Owner-Webmaster- Administrator www.rfqwork.com www.cnczone.com www.welderzone.com |
Natchamp, BobCAD-CAM has just released its BobART 3D image profiling software. You can import a picture and turn it into 3D toolpath automatically. It's powerful, easy to use and affordable. Check it out at www.bobcad.com. Sincerely, CNC Dude Last edited by CNCdude; 07-15-2004 at 08:34 AM. |
#10
Hello Guys! In these days I made some photo engraving into mirror glass: ![]() This work's gcode was created by DotG software what now released in English: ![]() Check the software here. It is free! |
#12
| Engraving Software | The Wizard | General CAM Discussion | 31 | 03-29-2005 06:38 AM |
| Software sales or "license transfers" | metlmunchr | BobCad-Cam | 3 | 07-05-2004 05:47 PM |
| Software for engraving | BriteHarry | General CAM Discussion | 8 | 06-06-2004 09:58 PM |
| Engraving Software Recommendations Wanted | paulried | General CAM Discussion | 16 | 05-21-2003 11:03 AM |
