Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 12-16-2007, 12:42 AM
jdsciencerules is on a distinguished road
Question CAD to CAM MENTOR INVENTOR
I have no idea what I'm doing but I know what I'm looking for. The basic concept is a (mircowave oven sized) CNC machine capable of “writing a name in glue”. Working directly thru an interactive pen display, the “name” is imputed utilizing digitizing tablet technology. Interfacing the tablet with PC controlled hardware, capable of continuous 3 axis movement with a vertical drop cool glue head, dropping glue as presented by the interactive pen display.
I understand the last process which is the application of the glue technology and its application but no nothing before that, any mentorship would be appreciated. Jim D.
Old 12-16-2007, 07:24 AM
ger21's Avatar
Plan on spending some serious programming time if you want it to be interactive in realtime, as you'll need to write all your own software. If you can live with write first, then let the machine run, there's a far simpler way. A member here, Switcher, has written a simple app that will create g-code from a tablet. You could then load the g-code into Mach3, which is capable of running your machine and applying the glue.
Old 12-17-2007, 12:47 PM
ger21, thanks for the responce, I understand a little about G & M codes. I understand little about a lot.
Is the first step to talk to Switcher and whats Mach3
I think I can live with "write first, then let the machine run,"concept.
By the way I don't have a machine yet it's still in the conceptual stage, all I have is an idea and I'm trying to get things up a running in about 8 months.
Do you understand what I'm trying to do ?
What type of PC should I have?
By the way I see your in Michigan, my wife's family is from Monroe, Yaeger Shoe's they now currently live upstate in Hale.
Inventor LT single phase Hypermill 2 08-03-2007 02:42 PM
Inventor to Cam/G VSNT Autodesk Software (Autocad, Inventor etc) 4 07-31-2007 05:39 PM
Inventor 11 single phase Hypermill 10 06-27-2006 11:07 PM
Adsk Inventor bpmufx Suggestions for the CNCzone.com site. 1 03-06-2006 12:50 PM
Inventor 8 cnc wizard Autodesk Software (Autocad, Inventor etc) 4 11-18-2004 02:38 PM
