Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 12-12-2007, 04:35 PM
Stueck1 is on a distinguished road
Design Cad 2000 export/import problem
Hello my name is Jason I go to highschool and I'm in tenth grade. The class is expriencing a problem when we create a oval or circle using design cad 2000 When we export the circle or oval from Cad and then import the file into CAD or Mastercam. Straight segements making up the circle or oval are shown when cutting with a CNC mill or router. How can we reduce or eliminate these segments.
Old 12-12-2007, 06:00 PM
ger21's Avatar
What format are you exporting it in?
Old 12-12-2007, 07:54 PM
I've tried exporting it in ".dwg" ".igs"
Old 12-12-2007, 08:28 PM
ger21's Avatar
I don't use DesignCAD or masterCAM, but if you post a sample .dwg file, I can tell you if the problem is with the DesignCAD export.
Your saying the circle is made up of small straight segments, correct?
Old 12-12-2007, 08:33 PM
harley4ever is on a distinguished road
Try the auto cleanup function. Not sure if Mastercam has that function or not.
Old 12-12-2007, 08:41 PM
jhowelb is an unknown quantity at this point
I use Designcad V17. I've notice that you need to select "save as a line" in the popup toolbar otherwise the circle is translated as a series of straight lines with angles every so far comming back to the start point when it is exported to dxf.
Old 12-12-2007, 08:44 PM
Hi Gerry, yes you are correct it is made up of small straight segments.
________________________
jason
Old 12-14-2007, 01:49 PM
dedvyned is on a distinguished road
Save your image or export as DXF file. We use Autocad 2008 but always save the file as Autocad 14-DXF.
Good luck
Old 12-14-2007, 10:15 PM
Thank you all for your responses.
Stueck1
ANCA 2000 Controller DNC problem derekj308 Machine Problems, Solutions , Wireless DNC, serial port 34 07-20-2011 09:05 PM
Mark Century 2000 Dnc Problem ozgurm Machine Problems, Solutions , Wireless DNC, serial port 5 02-17-2009 11:22 PM
Corel Draw x3 Export to dwg - import to ALibre Design - not editable cnc_gary Alibre Design 5 09-29-2007 10:34 AM
One Cnc 2000 Mill Professional Problem xak OneCNC 1 07-07-2007 08:19 AM
Solidworks intake manifold design problem Paul G. Swartz Solidworks 7 10-05-2006 04:52 PM
