| General CAM Discussion Discuss CAD/CAM software and Design software methods here! |
Hello, i'm trying to vectorize a JPG-image and convert it to DXF so i can engrave it. However i don't get any results. The first image is what it looks like after tracing bitmap in Inkscape, after that i do a File > Save as and select DXF. The second image is about what it looks like when i import it in any CAD-program. Have got the same result with different cad-programs so i assume i'm doing something wrong in inkscape. Could anyone help me with this? Thanks in advance for help! MaggoT |
| I don't think Inkscapes .dxf output works correctly in the Windows version.
| Stanford even hosts an online RV converter. http://vectormagic.stanford.edu/ I don't know if the output formats will be of any advantage to you.
Try using Corel and vectorized the JPEG image. Clean up the nodes the best you can and fix the curves then EXPORT this image as dxf. If you have Autocad you should be able to open it. Good luck |
| from image to wood? | shootingarts | Machine Created Art | 11 | 02-27-2008 10:27 PM |
| have converting problem | afri | Mastercam | 12 | 05-21-2007 07:37 AM |
| image files to dxf | Goran P. | Mastercam | 2 | 07-09-2006 09:54 PM |
| Mach3 converting dxf files problem | randyf1965 | DIY-CNC Router Table Machines | 7 | 04-18-2006 11:28 PM |
| Converting an image to a .dwg? | imsofaman | Autodesk Software (Autocad, Inventor etc) | 25 | 09-23-2004 02:53 PM |
