Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 11-27-2007, 12:32 PM
Joshrichard is on a distinguished road
Can you fool a CNC router table to cut a Cylinder from a flat design?
My question is if there is a way to make a flat design and fool the computer to make a Cylinder out of it?
Old 11-27-2007, 12:34 PM
ger21's Avatar
If you have a rotary axis, you can swap the Y axis for the rotary axis and cut around the cylinder.
Old 11-27-2007, 01:30 PM
Switcher's Avatar
Moderator
Switcher is on a distinguished road
Instead of a Y-axis, you could run "A, X, Z" assuming you have 3-axis, like ger21 said you will need a rotary axis.
You might want to read this for software, to help generate code.
Free DXF Files - Vectorink.com - myDXF.blogspot.com
Old 11-27-2007, 01:31 PM
Switcher's Avatar
Moderator
How complex will your part be?
If its simple, you could code by hand.
Old 11-27-2007, 01:51 PM
Switcher's Avatar
Moderator
Also If you swap that Y-axis, into an A-axis (rotary), it will need to be setup in your control (Mach3, etc...) as a rotary axis, unlike the Y-axis which would have been a linear axis.
The A-axis will work in degrees.
Build cnc router without linear ball bearings ?? Flat metal on flat metal with lube ? vroemm Linear and Rotary Motion 7 08-16-2007 12:26 PM
Moving table router design questions montanamac Open Source CNC Machine Designs 9 04-07-2007 09:27 PM
Design question CNC Router Table dan2004 Mechanical Calculations/Engineering Design 7 12-10-2006 07:55 AM
newbie design a plasma or router table or both alwaysready DIY-CNC Router Table Machines 0 06-13-2006 07:54 PM
CNC Mill Table not flat MrMagooo Machine Problems, Solutions , Wireless DNC, serial port 10 01-03-2006 05:01 AM
