| General CAM Discussion Discuss CAD/CAM software and Design software methods here! |
Hi Guys, I have been trying for a while to find a quick and simple solution to milling a small project which will give raised text like my example shown here. I can get as far as the design, but everything I try gives me a cutting path which produces the opposite - engraved text. I have sheetcam, cambam and lazycam (yes, I have no budget). I would appreciate any comments with no/low cost solutions. My DXF is included for expert perusal ![]() Thanks |
| You can create the raised text with Elefont, but not the border or background. http://www.armanisoft.ch/webdesign/elefont/Elefont.html Then, if you can convert the .dxf to an .stl, you can mill it with freemill. www.cncportal.com Accutrans should be able to convert it, it's $20. 30 day free demo. http://www.micromouse.ca/ There's a lot of free 3D software floating around, although the learning curve might be steep. You might want to look at Moi. http://moi3d.com/
| I didn't think of doing pocketing. Can't the same thing be done with SheetCAM?
| Hello Roland, Here it is done in CamBam... CamBam does not handle 3D dxf surfaces very well I apologise, so it looks pretty yuk when you open it up, but I deleted the unwanted objects which left the letters and outline as good old 2D splines. I then converted the splines to polylines and joined them. There are some instructions in this thread on how to do island pockets like this using regions and a pocket. http://www.forum.cambam.org/index.php/topic,39.0.html The latest version of CamBam does a much more efficient toolpath now I have added some optimisations. I've attached my final CamBam file and initial one (after tidying) for you to look at. Good Luck! |
| I would think you could generate this as a height-map in CamBam using a bitmap.... as well as by use of the DXF file you created.. hope this helps Danny (aka Yohudi)
__________________ What one man can do another man can do.. BitMaps to Models, 3D2Relief, tutorials and FREE CNC Software http://cnc4free.org |
| Use an image carve program and invert the grayscale so the cutter is high on the text area. Last edited by WayneHill; 11-17-2007 at 08:09 PM. |
| No expert help here - converting dxf to stl. then STLWORK2 (also a free 30 day demo) got the letters not the Oval/ellipse. Heres the output in NC plot (free), and the stlwork2. http://www.stlwork.com/ If you could save as stl files cuts out one bit of software and step. Took more time to find my software than to do the convert! Jim
__________________ Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it. Last edited by High Seas; 11-17-2007 at 11:22 PM. Reason: add url |
| Thanks Guys - what a dizzying array of solutions - and some really good suggestions for me to follow up. It's interesting to see something so simple become complicated. Then again, if it were so simple we would all get bored ![]() It's great seeing my name all over the place too! |
#10
#11
| Can try these shortcuts... CTRL+A (select all the objects) CTRL+P (convert all selected objects to polylines) CTRL+J (try and join all selected polylines...I used join tolerance 0.01) Then try make the region again. I hope this helps. If you want to upload the file, I can take a look. |
| Raised Letters | Astroguy | Mach Mill | 1 | 09-11-2007 07:42 PM |
| raised letters | zcases | OneCNC | 1 | 01-13-2007 11:53 AM |
| New Raised-Gantry CNC Router from Techno is Perfect Height for Foam Applications | carolpratt | Product Announcements & Manufacturer News | 0 | 12-05-2006 02:04 PM |
| Raised Letter Name Plates | RobtL | Benchtop Machines | 43 | 12-04-2006 06:31 PM |
| Question about Raised 3d Lettering Stamps | ROBTRONIX | General CAM Discussion | 13 | 09-11-2006 10:47 AM |
