Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 10-30-2007, 05:53 PM
Palafox is on a distinguished road
Running a gcode output file in the computer
I am an Anvil Express user. Sometimes I have to delete/insert some lines in the post processed file of a program output. Is there a program that can read the program output (g code) and run it in a graphical mode so I can see if I made an error in the edition process? Am I asking to much?
My old TOS machine with a Dynapath control can run the program in a primitive graphical form without moving servos or the spindle but my MAS CNC machine does not have this feature.
For example, Mastercam can generate the file to machine a part. This file can be loaded in another program to see it running? Which program would it be?
Best regards.
Old 10-30-2007, 09:06 PM
Switcher's Avatar
Moderator
Switcher is on a distinguished road
www.ncplot.com
Old 10-31-2007, 05:44 PM
Excellent recommendation. Thank you very much.
Old 06-10-2008, 05:56 PM
AllenCAM is on a distinguished road
Hi Palafox,
Are you still running Anvil Express? if so Anvil has it's own graphical toolpath verify called Anvil Verify that is an option when you load the software at installation. You can also run other third party G-code simulators, a good one is seeNC Mill.
If you are still using AE please let me know, I use it at times with a company here in oz.
Allen.
Tags
anvil express verify
Stereolithography file to GCode rweatherly Coding 32 06-04-2011 10:18 AM
Sprocket gcode/cad file creator mgreene General CNC (Mill and Lathe) Control Software (NC) 9 08-16-2010 02:56 PM
Running Two CNC Machines On One Computer Too_Many_Tools General Metal Working Machines 3 08-31-2007 02:27 PM
Can Someone Covert File To Gcode? bcnc General CNC (Mill and Lathe) Control Software (NC) 21 06-26-2007 09:16 PM
How to mirror GCode file? anoah General CAM Discussion 6 07-08-2003 12:26 PM
