Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 05-28-2004, 02:12 PM
i228208 is on a distinguished road
Accuracy problems
Hi
I have a sherline lathe with sherline driver box and i am having the following problems.
After about 40 lines of G code from vector cad cam my lath is about 0.40 mm to 0.60 mm out of tolrence. If i jog say 30mm using mach 2 its perfect no problem but if i run g code i end up geting accuracy problems.
I use vector cad to design my part and turn it in to g code then export it to mach 2
If i used limit switchs to reference zero every few steps would that make my lath more accuret
I would be greatful for any sugestions
C Morton
Old 05-28-2004, 02:30 PM
Gold Member
imserv is on a distinguished road
Adding reference switches will not correct for an inaccurate machine. If you run the program without cutting material, do you still lose position?
It sounds like you may be losing steps during the rapid commands. Change all the G00 codes to G01 and see if you still lose position. If not, reduce your max velocity, which is what is in effect during rapids.
This assumes that you have accounted for backlash, part movement in the vise, tool movement from excessive pressure, etc.
Fred Smith - IMService
Old 05-28-2004, 03:40 PM
Hi
Thanks for the reply i am going to spend saterday trying to get this mashine accurate.
I still loose position when not Cutting. the driver box is a sherline one with there stepper motors but.
As the box is brand new and if performance is still bad i will have to buy gecko drives but id rather not have to shell out 160 pounds plus shipping.
Thanks chris
Old 05-29-2004, 04:32 AM
Hi have slowed the lathe down to a feed rate of 10
Both the x and the y axis are out exactaly the same. 0.04mm
but when single steping there is no error only when i run say 60 lines of G code, the error when i run 132 lines of G code is 0.04mm.
Is the sherline driver box a good controller or have i been riped off.
chris
Old 05-29-2004, 08:12 AM
Gold Member
Sherline Controller
Your program probably has rapid moves from the VectorCad-Cam lathe roughing function. In the Vector NC editor, use the Edit-Replace function to temporarily (for testing only) change the G00 commands to G01.
The controller is fine.
Did you change the G00's to G01's like I suggested? Changing the feed rate will not affect the rapids. Only if you change all the moves to feeds will you be able to determine tha maximum traverse rate that the machine and controller will handle.
Sherline has a support forum at
http://www.sherline.com/forums
Most likely someone there will be able to tell you how to adjust your setup to prevent lost steps.
http://www.cadcamcadcam.com
Old 05-29-2004, 08:53 AM
hi again
I have tried what you have suggested by taking out the G00 comands to no sucsess
After 132 lines of G vode the error is .04mm this doubles when i run the same gcode again.
In mach 2 i can set the step pulse longer than 15us as specified by sherline its set as 14 and the pre direction time wont go any higher than 5us seconds.
The mashine i run it on has only mach2 on no other softwere is running in memory.
I am starting to think this controller was designed for EMC and Not any other softwere.
As there are other people who have had problems with the controller.
chris
Old 05-29-2004, 11:39 AM
Gold Member
.04 MM is a far cry from the .4-.6 MM that you reported when this thread started. Is that radial or diametral? On many hobby class machines .04 MM will be within the probable error due to backlash, lead screw variation, heat effects, etc, etc, etc.
However, since you can repeat the error, some more questions may be in order.
Are you operating in Absolute mode(G90)? Incremental mode has some problems that may affect how you measure the error.
Are you returning to the same position when the program ends? In other words, do you program a final motion that returns the tool to the exact starting position?
How are you measuring the error? With an indicator? Is the error accumulative or does it vary + and -.
You didn't say you were trying to rig up Mach2 with the Sherline controller, what other surprises do you have? There is a yahoo group for Mach 2 support.
Old 05-29-2004, 12:12 PM
The .4 to .6 was for a large g code program
0.04 was jus for 132 lines of code the error doubles when you doble the lenghth of the G code so you can imagine the error is masive when the code is 100 lines long.
When the program ends i hit the go to zero button, by looking at the dials and looking at the DRO on the screen i deduce the error.
When is say there is no error joging, there will be but it is so small and for every move the errors ADD.
The error is accumulative and it is always - . I have sheilded all cables checked the earth, checked analogue and digital noise. but all seem OK. The only point i can think of is this mack 2 wont let me have a pulse time bigger than 14us and sherline specify 15.
I run it on a dedicated PC with nothing running in memory.
Oh both X and Y have the same error exactaly
chris
Old 05-29-2004, 12:52 PM
Gold Member
Does the error correspond to the number of lines of G-code, or to the distance traveled. You could quickly check this with a program from Vector.
If distance traveled, you may need to adjust the steps per mm(inch).
You didn't respond to my questions about using an indicator to independently verify the error. Your screw pitch may not be set correctly, that would account for the problem that you are having, and the fact that both X and Y are the same. From what you have posted so far, the problem is not clearly software/ hardware, or just adjustment.
htp://www.cadcamcadcam.com
Old 05-29-2004, 01:36 PM
HuFlungDung's Avatar
Moderator
Chris,
I would try a more methodical approach than just "running some Gcode". Make a single axis program, consisting of very short, medium and very long movements. Check the distance moved after each single command is read.
Check the distance moved in jog mode. Does it correspond to the display? Again, try short, medium and long movements.
Check how accurate the machine returns to position after running a simple positioning loop: forward and back to the same two endpoints. Do it once, then several times, to see if you can find a systematic error. This is how you troubleshoot, not by running actual programs.
  #11   Ban this user!
Old 05-30-2004, 03:44 AM
Hi
Both axis are out by the same amount
Y axis
Moving the Y axis in and out 20 mm 2 times there is an error of 0.01
4 times an error of 0.02mm
6 times 0.03mm
8 Times 0.04mm
10 times 0.05mm
And the same for the X
I have tested the lathe dials by cutting a some metal manually and measuring it with a micrometer and its perfect from this I can deduce there is nothing wrong with the mechanics of the lathe.
If i repeat the above with a g code program the error is the same
Chris
  #12   Ban this user!
Old 05-30-2004, 04:15 AM
inthedark's Avatar
inthedark is on a distinguished road
Check these settings on the controller and CAD/CAM; unfortunately, i am unfamilliar with sherlines.
Does your controller support modal commands?
Are you specifying G21 for metric in the code, and 3 or 4 digits to the left of your decimal?
The circular interpolation tolerances on the controller vs the CAD/CAM.
Circular movement expected by the controller? Full, Half, or Quarter (you can try arcs as lines for testing)
G02 and G03 requirements like Coordinate values (incremental or absolute)
My coordinates have to be absolute, but use incremental I, J, K during circular moves.
The debounce count set too low can cause this as well on some controllers.
Just a few thoughts
"Plan your work; Work your plan"
Ballscrew Basics Swede Linear and Rotary Motion 101 04-16-2012 08:09 PM
Traub TNL 26 Accuracy meconer Machine Problems, Solutions , Wireless DNC, serial port 2 12-10-2009 03:57 PM
Stepper RPM and Accuracy Question. Please Help! David Bord Stepper Motors and Drives 3 05-25-2005 02:27 PM
Fanuc Problems scuba General Metalwork Discussion 6 03-19-2005 01:19 PM
Problems aligning motor with lead screw. SCCoupe DIY-CNC Router Table Machines 11 02-15-2005 06:33 PM
