Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 09-17-2007, 01:55 PM
FishGuy876's Avatar
FishGuy876 is on a distinguished road
Computing Cable Rotation From XYZ Point Data
Hi! I'm wandering if anyone can help me with a little bit of a math problem. I'm working with some CNC software that I need a little bit of help on. Some of the items we are bending use XYZ point tables to computer in virtual space, where points of a cable intersect. Using the radius wheel, we then can compute where the arcs go etc. so the end result is a bent & formed semi rigid cable. I need help trying to compute the rotation angles for our bender though.
The bender has three motors, one for the horizontal cable feeder, one for the bending arm, and the third rotates the cable in a clockwise/counter clockwise form. A typical XYZ table would look something like:
**PT.# **X **Y **Z **
1 227.15 -68.07 8.16
2 227.15 -85.00 8.16
3 203.00 -70.00 -15.00
4 175.00 -68.70 -19.40
5 147.00 -60.00 -50.00
6 105.35 -60.00 -60.00
7 92.43 -59.54 -80.95
8 92.43 -46.11 -67.52
Can anyone point me in the right direction on how (mathematically) I can compute the rotations needed from just the XYZ points? Links to such documents welcomed. I have been able to do everything else except this. Any help is greatly appreciated!
AndyK
converting point to point programs kevinwd1 General CAM Discussion 2 06-11-2007 11:45 AM
New xyz data point file after decentration AWTECH OpenSource Software 2 08-16-2006 10:19 PM
Where can I download Point cloud sample data ?? Calico Rhino 3D 0 03-19-2005 09:16 AM
point data in autocad trubleshtr General CAM Discussion 3 03-11-2005 05:32 AM
D&M Computing CNC 9 Lathe Info??? TD1932 General Metal Working Machines 1 10-11-2004 03:16 PM
