Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 08-04-2007, 11:02 PM
PeteGallo is on a distinguished road
How can I creat tubular 3D enteties(with arcs)
I am using progeCad wich has very simillar commands as AutoCad.
I am tring to creat a tubular frame with many arcs.
I do not see an easy way.
What method works best for you?
Thanks for any help,
Pete Gallo
Old 08-05-2007, 07:47 PM
bborb is on a distinguished road
I draw an arc in the X/Y plane, then I draw a spline that "squirrels" down the Z axis. Next I extrude the arc, defining the spline as the extrusion path.
HTH
Old 08-05-2007, 09:22 PM
ger21's Avatar
You may need to extrude it in multiple pieces and boolean (union) them together. As was mentioned, use the arc as the path and extrude along the path. In Autocad, you choose the extrude command, then "p" for path, and select the path.
Old 08-05-2007, 10:33 PM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
I don't use AutoCAD but does it have a Sweep Function for Creating a Tube along a Spline???
Just throwing it out there.
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Old 08-06-2007, 06:51 AM
ImanCarrot's Avatar
ImanCarrot is on a distinguished road
In Autocad you can just extrude a circle by however much you want, but if you're using lines or arcs you need to convert them to a polyline (PEDIT command with "Multiple" option). If you're making a "tube" then you need to do the outside then subtract the inside from it (SUBTRACT command).
You can change the colour of the faces and stuff by using the SOLIDEDIT command.
I know this is all for ACAD, but you say that the commands are similar to your system. Apologies if this doesn't help!
I love deadlines- I like the whooshing sound they make as they fly by.
Old 08-06-2007, 09:15 AM
ger21's Avatar
Make your circle a region and subtract a smaller region from it before extruding, which will let you extrude an actual tube.
Toby, you can extrude along a spline, but I doubt he'll be able to get a spline drawn correctly for his application. I wouldn't even try it. A 3d polyline can't have arcs in it, so that's why I suggested making it in sections and joining them together.
Old 08-06-2007, 10:52 AM
kuna2 is on a distinguished road
how can i convert drawing file from autocad to master cam ?
pls help me
Old 08-06-2007, 11:33 AM
extrude along a path?
progeCad has petty much the exact commands as AutoCad.
Gerry extrute and "p" for path command works but I am not sure what to enter for the path I selected the 2 end ponts of the arc but that did not work.
bborb how do you create the spline to follow the arc? This method sounds interesting could you describe a spet by step for me (I am new to CAD).
Thanks for the help,
Pete Gallo
Old 08-06-2007, 11:34 AM
ImanCarrot's Avatar
I done a quick drawing in Acad using 3 arcs, a circle hole and a tapered square hole.
I drew the arcs, used PEDIT and MULTIPLE option with JOIN option to combine them. I then drew the circle and the square, EXTRUDED the arcs, the circle and the box (used a minus 10 taper on the box).
Next, I went to 3d SW isometric view and SUBTRACTED the circle and square hole from the arcs and Gourard shaded it... here's a piccy.
PS, if anyone knows how to increaaase the resolution of the arcs and circle can they let me know please... I'm not an expert and don't know how ot make "smoother" ccircles and arcs.
Thanks in advance
Iain.
PPS! Exporting from ACAD to Cam- can your Cam prog accept DXF files? if so then you can "Save As" and select the DXF option in the file dialogue box (you would think it would be under Export, but it's not, it's "Save As"). Cheers!
Iain
Old 08-06-2007, 11:49 AM
Roll Over Protection cage
Hi Imancarrot,
I am trying to create tubes with arcs. Basically a roll cage (ROP) made up of tubes (pipes) in 3d which arc in all three x,y,z axis.
Thank You
Pete Gallo
  #11   Ban this user!
Old 08-06-2007, 11:52 AM
ImanCarrot's Avatar
Ah! sorry! my bad. Gotta shut my lab up for the day now (home time wheeee!) but I'll have a look tomorrow
  #12   Ban this user!
Old 08-06-2007, 12:17 PM
JROM is on a distinguished road
Autocad
If you are using Autocad I feel sorry for you!
Find out if you can extrude or sweep a circle along a curve to form a surface.
Good luck!
Be carefull what you wish for, you might get it.
Huge Arcs HELP ????? Biggermens Mach Software (ArtSoft software) 3 04-26-2007 09:50 AM
Huge Arcs Biggermens Mach Lathe 0 04-23-2007 11:49 AM
Smoothing 3d arcs? stevespo BobCad-Cam 14 04-20-2007 07:46 AM
Points on arcs gguidi Autodesk Software (Autocad, Inventor etc) 2 07-25-2006 08:49 AM
Casting silver in a tubular shape Konstantin Casting Metals 4 07-22-2004 08:15 PM
