Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 08-03-2007, 03:56 AM
newbambory is on a distinguished road
Recommend software for this job
Hello,
2mm thin sheet metal needs to be bent to match the side of a classical guitar.
After it's been bent the length will be 340mm and the width (on one end 120mm and on the other end 150mm).
I need the flattened drawing. Which software can do that painlessly?
Thanks, John
Old 08-03-2007, 10:06 AM
Tony the Ferret's Avatar
Tony the Ferret is on a distinguished road
Cimatron E has a Progression die solution and claims to be "the fastest blank in the west"
Send me your file and i will answer you if it is possible
Old 08-03-2007, 12:25 PM
There isn't much to send.
Just try this: create a surface or sheetmetal using spline. Then try to flatten it.
For anybody who might be interested I found out so far that SolidWorks can't do this since the sheet metal (the side of a guitar) is created with Spline.
To be flattened SolidWorks requires that bend faces are limited to
cylindrical, planar and conical shapes.
Please recommend a encoder moto21 Gecko Drives 1 09-27-2005 12:17 AM
Recommend Websites murphy625 CNCzone Club House 7 05-18-2005 08:40 AM
Please Recommend a DNC system CBNDude Machine Problems, Solutions , Wireless DNC, serial port 2 03-11-2005 12:46 AM
Recommend this software? kdoney Rhino 3D 6 05-20-2003 06:38 AM
Recommend this Software? kdoney General CAM Discussion 2 05-13-2003 08:06 PM
