Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 08-02-2007, 05:22 PM
AlfSkaar is on a distinguished road
CAM Programming helps a new begynner with the Sherline Mill 2000 (2010)
First the requirement
1. it has to have a Post-processor for the Sherline Mill, EMC (CNC) that runs the g-code.
What I mean is that the g-code that the CAM program make has to be able to run without
any mod on the EMC CNC software to cut the part
2. make g-code from this part
Is there anyone who can help me to find the software I need or somoene who has some experience in this area? It would be greate if someone could point me in the right direction.
If somone would like to make a g-code from the stl file just to see how the It works, I could post it to you.
What programs are other sherline owners using to make g-code ?
Alf
I have did it with MeshCAM, FreeMill, and since I don’t now how proper g-code has to look, I ‘m lost, I have to say that the code that MeshCAM made looked the best on the back plot, but It has errors.
I looked at:
www.hobbycadcam.com
www.mecsoft.com
www.microtech.se
www.vectorcam.com
www.webersys.com
www.bobcad.com
www.edgecam.com
www.hsmworks.com
www.mastercam.com
www.solidcam2007.com
www.deskam.com
www.deskcnc.com
www.microtech.se
www.gsimple.gr
www.stlwork.com
www.mecsoft.com
www.softsquad.com
www.predator-software.com
grzsoftware.com
ACE Converter by DAK Engineering
Som are real versions and som are demo versions and will not make g-code in demo mode. Other were too complex for me to be abel to make g-code or I could not make it work.
Old 08-03-2007, 10:14 AM
Tony the Ferret's Avatar
Tony the Ferret is on a distinguished road
code
AlfSkaar
why are you having problems, is it because you are expecting something for nothing, because that is what demo versions will give.
You do not say why it is a STL file you want to machine, to create this file in a solid modeling software (WorkNC-CAD) should take no longer than 5 mins, and the same to generate the g-code for your machine (WorkNC)
i will help you if you need, just send me the file
Old 08-03-2007, 11:11 AM
ger21's Avatar
MeshCAM and Freemill are the wrong tools for that job. All you need is a 2D .dxf and something like SheetCAM, or an CAM that will create 2.5D toolpaths from a 3D model.
Old 08-03-2007, 03:31 PM
Originally Posted by Tony the Ferret View Post
AlfSkaar
No.
I don't now why, i just had the impression that this is what most programs
and users are using. I'm a newcomer in Cam/CNC after all :-)
Sorry and thank you for bearing with me
That will be great. What type of file would you like to have ?:-)
What program for the Cam part are you using ?
And what type off mill and CNC software are you using to run the g-code
Thank you
Alf :-)
Old 08-03-2007, 04:26 PM
Thank you I`m a beginner in the Cam area, and I don't now where to start looking after software and trying different programs and trying to make the tool path, without the experience of what is what.
Today i learn what conturing is.It might be easy for all off you but i'm like a small baby,I have to learn it.But I have to say this is a very interesting
area( Cad, Cam, CNC.)
And i have som ideas for what i can use it for.I can use this in my hobby or sports.The posibilities are endless.For instance in:
RC racing, 12 scale only
speed windsurfing
skiing
bicycle
I have made a camera with a GPS in order to measure the speed in the Video (real time).
I have already made two systems; one with cable and a wireless one.
i use video sender from www.vtq.de
And now i can make a proper box to put the camera and the controll stuff in :-)
And it goes on :-)
Many thanks for the help
Alf :-)
Old 08-03-2007, 05:00 PM
Today i talked to the the company that makes Vcarve Pro and during the phone call he actually made the g-code.I have to say that i'm very impressed by how fast he made it.It can also make tabs so it will not brake loss from the stock.
I also talked for quite a long time with a guy that uses Master Cam befor I talked to "Vcarve Pro".He told me that he needed about 4 hours to make the g-code in Master Cam, he did make a small g-code program by hand, 23 lines of code to show me, and told me that this program cold possible be writen by hand.
Alf :-)
Old 08-06-2007, 03:50 AM
Thank you
Alf :-)
Alf, send what you have, or just a 2D sketch, drawing, iges, dxf, solid works, i use WorkNC for programming, and can out-put Gcodes to suit your needs
Old 08-27-2007, 08:58 AM
Talking
Thank you all for the help
if you need a nice software to do the job have a look at "Vcarve Pro 4"
www.vectric.com
So very nice to use. :-)
Alf :-)
Old 09-03-2007, 09:39 AM
VMware EMC2 Ubuntu v6.06
I have made a VMware than runs Linux Ubuntu for testing off g code under Windows XP, it runs under WMvare player
any one have intrest, if yes you can download it from my ftp server
EMC Sherline
Alf :-)
New servomotors for my Sherline 2000-CNC - pics Neil_J Benchtop Machines 2 06-28-2006 09:42 PM
FlashCut CNC Mill 2000 sniffles General Metal Working Machines 6 03-01-2006 07:27 PM
2010 Tool Not Available - Fanuc Om PPM Fanuc 3 08-24-2005 04:22 PM
2010 power requirements? Splint Servo Drives 1 06-26-2005 09:21 AM
Mill Expert Helps Build the Ford GT OneCNC OneCNC 1 11-06-2003 08:17 PM
