Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 04-21-2004, 07:05 PM
BriteHarry
Guest
Posts: n/a
Software for engraving
Hi people,
I need a couple of basic words like "left" "right" etc engraved into some aluminum about 0.015" deep using a 1/8"dia d-bit 60deg cutter.
Does anyone know of some free or low-cost software I can get that will generate the toolpath or a dxf file? Once I have the words I need in gcode or dxf I will not need the software again.
I tried DeskEngrave, but it does it in a million little steps and it also has some overlapping lines when generating the text.
Old 04-21-2004, 07:45 PM
Rekd's Avatar
Rekd is on a distinguished road
You could long hand it in about 2.34 minutes.
'Rekd
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
Old 04-22-2004, 06:02 PM
gmfoster is on a distinguished road
Desk Engrave is totally free and will generate the gcode for this with no problem. Just do a search it with Desk Nc and other software from the same guy.
Old 04-22-2004, 08:15 PM
ger21's Avatar
http://www.5star-shareware.com/Graph...tline-art.html
Old 04-22-2004, 11:15 PM
balsaman's Avatar
balsaman is on a distinguished road
Just draw the letters in a cad program the hard way? That or use text in autocad and explode it with the express tools text explode tool.
Eric
I wish it wouldn't crash.
Old 04-23-2004, 06:27 AM
wjbzone's Avatar
wjbzone is on a distinguished road
If you have Autocad, do what balsaman said. Type the text, explode it. (use a shx font)
Then convert the exploded lines to polylines.
You can then export the gcode using ger21's gcode exporter or my gcodeout. (both free downloads in autocad forum here in cnczone)
Bill
Old 04-30-2004, 04:07 PM
kong is on a distinguished road
Is there a something similar that will create 3d toolpaths for varied-depth text?
Old 04-30-2004, 05:43 PM
Gold Member
imserv is on a distinguished road
Vfontz, but you will need Vector-cam to process the toolpaths.
http://www.vectorcam.com/abcv1.jpg
Info Here:
http://www.vectorcam.com/vfontzt.html
Fred Smith - IMService
Old 06-06-2004, 08:58 PM
dcarr is on a distinguished road
VS3D can do varied-depth text and general 3D relief surface sculpting (and can output the necessary tool paths in G-code and other formats). VS3D handles true-type fonts and can do raised lettering (cut away the background and leave the letters raised above it). VS3D's home page is at:
http://www.DesignsComputed.com/vs3d
Daniel Carr - President,
Designs Computed, LLC
Engraving Software The Wizard General CAM Discussion 31 03-29-2005 05:38 AM
Software sales or "license transfers" metlmunchr BobCad-Cam 3 07-05-2004 04:47 PM
***One stop CNC software guide*** ynneb DIY-CNC Router Table Machines 4 05-27-2004 04:31 PM
What software are you using? BeerFizz DIY-CNC Router Table Machines 4 12-06-2003 03:15 PM
