Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 07-10-2007, 08:06 AM
gls48 is on a distinguished road
Lightwave modeler
Does anyone know of Lightwave modeler? I have been using it for years to build catalog models but have never learned to use any other cad program. What would be most useful would be if I can use Lightwave to generate code for a mill. LW will export DXF but as it is 3D, I’ve never figured out if it can be used to generate a program.
George
Old 07-10-2007, 09:04 AM
ger21's Avatar
Yes, I use it. Depending on what format you're CAM program supports, you can export .dxf, .obj, or .3ds models. I use an .stl export plugin from Sean Moyer's Chrome Cow site to export models and bring them into MeshCAM.
Lightwave 3d and cnc machining breakstuff General CAM Discussion 5 09-26-2007 02:25 PM
Lightwave 3D to g-code Ursine Mach Software (ArtSoft software) 9 04-15-2005 02:27 PM
Cool cheap 3D modeler ger21 General CAM Discussion 0 04-05-2004 11:04 PM
