Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 06-15-2007, 02:23 PM
Budzy22 is on a distinguished road
CATIA NC Programming
Is anyone familiar with programming with Catia. I have been using this software for a little while but I am not able to get a really smooth finish. It seems as though the finish is always choppy. Anyone have any advice?
Thx.
Old 06-16-2007, 08:01 PM
tebisuser is on a distinguished road
i dont know catia , but you can try to make a smaller chordal deviation
But you problems are not solved if the milling machine dosent help you , i mean if the machine can not keep the points from the nc programm
can you post a pictrue what you try to finish ? and what machine you use ?
Old 06-29-2007, 07:41 AM
Thank you for your response. My stepover/scallop height would be set at .001 and my machinig tolerance at .0001. My program was huge. But I had to do this to get a good finish. We are using an Acer Bedmill. The machine is fine. We have created a program with EdgeCAM and the finish came out better and the program was a lot smaller. I cannot find anyone who knows the trick to getting a good finish using Catia.
Old 06-29-2007, 07:42 PM
Smile
we are talking in mm or not
we use fidia controler and tebis for programming and our finish is like mirror
our programms are in range of 700 -800 MB for molds
for finishing cut only ......24 hour long
Old 06-29-2007, 11:47 PM
charlie huffman is on a distinguished road
I am a Catia programmer and it sounds like you need to loosen up the mach/tol (.0001 will add a ton of points with no regards to finish) and tighten up your scallop height to .0005 for a much better finish when kellering a twisted surface. Change your mach/tol to .001 for every M.O.
A Catia section In Programming and design Wiseco Suggestions for the CNCzone.com site. 0 04-12-2007 03:49 PM
How to convert DWG to CATIA CnC_BoY General CAM Discussion 17 03-30-2006 09:29 AM
What is Catia CNCadmin General CAM Discussion 20 05-20-2005 05:17 PM
Catia Programming/Training V-4? wocowski General CAM Discussion 0 11-21-2004 03:08 AM
Catia whiteriver General CAM Discussion 5 07-02-2004 01:14 PM
