Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 05-05-2007, 11:01 PM
sunmix is on a distinguished road
Does Anyone Knows What This Software Is?
Hi everyone, I was wondering what software is this, I can't figure it out because the picture was not specific enough. Anyone knows what this software is? Thanks!
Old 05-05-2007, 11:20 PM
Al_The_Man's Avatar
It appears to be a canned shape program as used on Plasma/Gas cutting etc.
You pull the shape up you want and enter the size parameters required.
Some will also offer nesting of the same parts or more than one part.
In this case the parts can be reversed or rotated in the nest for maximum material use.
For example the picture shows shape 01 pulled up.
Old 05-05-2007, 11:24 PM
So does anyone know what is the software name? I can't google or yahoo it anywhere.
Old 05-05-2007, 11:28 PM
Al_The_Man's Avatar
Are you sure it is a separate package, as most of these packages are part of the controller system, otherwise it means export/import into the controller.
Old 05-05-2007, 11:30 PM
yes i'm very sure. the given package would be together with mach3, there is no way that will be a mach3 wizard, it does not look like a mach 3.
Old 05-05-2007, 11:35 PM
Al_The_Man's Avatar
Unless someone recognizes it, you could Google Plasma Nesting - Custom Shape Cutting etc.
This is an example http://www.mtc-software.com/products/pronest.php
For custom shapes, it is sometimes easier to write your own macros, if the software does not have it.
Old 05-05-2007, 11:39 PM
Okay thanks for the tip, I'll do it right away
Old 05-05-2007, 11:42 PM
eek wait! I don't know how to write macros that makes custom shapes 0.0
Old 05-05-2007, 11:54 PM
Al_The_Man's Avatar
Thats the beauty of having them built in, the Plasma/Cut software I use not only has them built in, but you can add your own, the advantage is the canned shape appears on the screen when you size it, whereas a straight macro program only exists in software until you actually run the part, then it will appear on screen if the control has path display ability.
You need a book on parametric programming to write macro's.
First post in the software dept. Free cnc software? runinbymdnt General CNC (Mill and Lathe) Control Software (NC) 2 02-06-2007 10:49 PM
