Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 04-21-2007, 09:22 PM
PeteGallo is on a distinguished road
Question How can I 3d/Solid a line drawing?
I have attached a dwg file with two solid entities.
In between the two solids I have A line outline of what I would like to solid union with the other two entities. The one entity is a boxed rectangle and the other is a cylinder.
I am useing progeCad 07-PRO. witch should have very similar commands as AutoCad.
Thank You,
Old 04-21-2007, 09:38 PM
Gold Member
Ken_Shea is on a distinguished road
Pete,
Could not open the file here due to errors.
do you have a .dxf ?
Old 04-21-2007, 09:56 PM
Smile .dxf format
Hi Ken,
Attached is the .dxf format.
Thanks,
Pete
Old 04-21-2007, 10:03 PM
Gold Member
OK, well that did not work either for me, opened up but nothing but a few lines, did you day you have a solid model of it with just the geometry included that needed modeled to a solid ?
I never seem to have any difficulties with these formats.
.igs
.stp
If you want to try again, I am game
Old 04-21-2007, 10:23 PM
solid
I can't save as .igs or .stp .
Are you using AutoCad if so what release. I have a list of .dxf AutoCad formats to choose from :
release 2.5 to release 14
AutoCad 2000 to 2007
Yes I have a 3d shape outlined with 2d lines I would like to convert to a 3d solid.
Thank You,
Pete
Old 04-21-2007, 10:30 PM
Gold Member
Pete,
I have to import .dxf as I am using OneCNC
It does not say but I believe it is 14
Old 04-21-2007, 10:40 PM
Gold Member
Pete,
you got me thinking, if you cannot export to a .igs / .stp what can you import as a solid ?
Old 04-21-2007, 10:42 PM
AutoCad release 14
Hi Ken,
Try both of the AutoCad release 14 files attached. One is binnary and the other is ASCll.
Thanks,
Pete
Old 04-21-2007, 10:47 PM
Gold Member
Pete,
I am sorry, I do not know what is going on,
Here is all I see
Old 04-21-2007, 11:00 PM
Wow
Wow thats weired. Oh well thanks for trying Ken. The file prob. could be on my end.
Thanks,
Pete
  #11   Ban this user!
Old 04-21-2007, 11:10 PM
drafting101 is on a distinguished road
I was able to get the file open in autocad 2005. now what are you trying to do?
Never mind figured it out. Would you like me to do that for you?
  #12   Ban this user!
Old 04-21-2007, 11:16 PM
what kind of file can you import?
DP4/TT1 socket drawing Michael M AjaxCNC Control Products 0 01-29-2006 01:31 PM
Need drawing converted seansear Employment Opportunity 5 01-27-2005 09:00 AM
Which came first, Solid Edge or Solid Works? Arnie General CAM Discussion 3 09-15-2004 06:25 AM
scanning a drawing kenlambert BobCad-Cam 5 03-08-2004 12:47 AM
Drawing ? Ken_Shea OneCNC 4 06-08-2003 10:54 PM
