Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 03-31-2007, 10:55 PM
PeteGallo is on a distinguished road
Method to internal/external thread ?
Hello,
What would be the best way to go about adding a large fastener type thread to my design.
Should I creat it from scratch?
I am using progeCAD, most commands are the same as AutoCad.
Thanks,
Pete Gallo
Old 04-01-2007, 12:55 AM
impact is on a distinguished road
Proper helical 3d threads in autocad are impossible without addon LISPs. They are also completely unessisary for manufacturing drawings. In 3d just make a hole to the minor diameter of the thread, and in the layout if you are not making a section just draw two hidden lines representing the minor and major diameters.
Old 04-01-2007, 08:19 AM
thread
Hi Impact,
The part I have designed will be cut on a cnc mill (which I don't have yet). Also the large diameter (70 mm) internal and external thread will be done with the mill.
If the thread is not in the part design where would it be plotted. Maybe with the CAM?
I am new to this.
Thank You
Pete Gallo
Old 04-01-2007, 02:03 PM
elgamiller is on a distinguished road
thread milling is easy enough to program on the shop floor and you don't realy need to use cam for it
In Heidenhain (not familiar with many other controlls) all you do is move out to the major dia of the thread (in x) then an incremental polar rotation of 360 degrees and an incremental z move of the pitch (with a thread comb type of cutter), up is better as you mill away from the swarf.
Old 04-01-2007, 07:46 PM
threads
Thanks for the info. I would rather do it the shop than pull my har out with CAD.
Old 04-02-2007, 05:48 AM
Syil_Australia is on a distinguished road
Hello Pete.
If you use Mach3 there are Wizards for the Internal & External threading..
cheers
Frans
Old 04-03-2007, 09:50 AM
to thread or not to thread
Hi Syil_Australia,
I do not have the CNC equipment as of yet but could you give me the name of the Wizards for the Internal & External threading so I can file the names for when I will need them.
Pete Gallo
1/4 NPT External thread program JerryH G-Code Programing 5 08-28-2008 07:37 AM
Internal Thread Grinders Zumba General Metal Working Machines 4 03-03-2007 08:28 AM
2-1/2 External NPT on Okuma Lathe jdr1961 G-Code Programing 2 02-14-2007 09:12 PM
Acme Internal Thread 1 ½ - 0.250P-2.000L-ACME-2G-LH (8 START) Help pandiyan.innova CNCzone Club House 7 11-16-2006 05:47 AM
What's the best method to turn a thread and a 3/32" bore concentric? Darc General Metal Working Machines 6 10-27-2006 06:34 AM
