Page 1 of 2 12 LastLast
Results 1 to 12 of 15
Thread: how can i make a hole through a solid (progeCAD)
    Jan 2007
    I have a solid cube and would like to put a hollow cylinder through it.
    I am useing progeCAD 2007 witch should have similar commands as ACAD.
    Thank You
    Mar 2003
    Shelby Twp, MI....USA
    Create a solid cylinder and subtract it from the cube. If it's the same as AutoCAD, that is.
    Jan 2007
    Talking that was too simple
    Thanks Gerry,
    Dam that was easy.
    I've been trying to figure it out for 2 days. I had hoped the solution would have been more involved so i would't feel so dense. Needless to say I am new to 3D.
    Pete
    Mar 2003
    From looking at ProgeCAD LT that I have installed here, it appears to be virtually identical to AutoCAD, except LT doesn't have solids. So I should be able to answer any questions you might have, based on my AutoCAD experience.
    Jan 2007
    can I convert a revolved surface to a solid
    I started with an arch revolved it. Is it possibles to covert this entire entity to a solid.
    Pete
    Mar 2003
    I don't think so , but AutoCAD has both revolved surfaces and revolved solids. Check the help file. A revolved solid is created the same way as a revolved surface, just a different command. revsurf for surfaces, revolve for solids.
    Jan 2007
    revolve
    progeCAD does have revolve solid.
    I will try that what should I start with when I use the revolve solid (2D lines and arc)?
    Thanks,
    Pete
    Mar 2003
    It may require specific geometry, like a closed polyline. Not sure exactly, but this is what AutoCAD will let you use.
    Lines
    Arcs
    Elliptical arcs
    2D polylines
    2D splines
    Circles
    Ellipses
    Planar 3D faces
    2D solids
    Traces
    Regions
    Planar faces on solids or surfaces
    Jan 2007
    revolve steps with ACAD
    Hi Gerry,
    What are the steps in AutoCAD to revolve a solid.
    When I try it with progeCad I start with lines and arc closed, select revolve solid and I am not able to select the entity and command line asks for opposite corner.
    (unfortunately not much help in the help files)
    Thanks,
    Pete
    Mar 2003
    They might be entities that are not allowed. Does the help file say what can be revolved? In AutoCAD, you select the objects, and choose the axis of revolution.
    Jan 2007
    1 selected curves are rejected
    I find that I am able to select a closed poly entity to solid revolve.I can choose the two axis then when I enter the revolution angle (360) I recieve this error message :1 selected curves are rejected.
    Thanks,
    Pete
    Mar 2003
    Post a .dxf of what you're trying to revolve and I'll look at it. But I'm heading out the door, and won't be back til late.
  • Page 1 of 2 12 LastLast
    1. ProgeCAD free version
      By dleroi in forum General CAM Discussion
      Last Post: 01-16-2008, 03:29 PM
    2. ProgeCAD
      By lsbtcm in forum General CAM Discussion
      Last Post: 11-26-2006, 02:47 PM
    3. Which came first, Solid Edge or Solid Works?
      By Arnie in forum General CAM Discussion
      Last Post: 09-15-2004, 07:25 AM
