Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 03-09-2007, 08:33 PM
skibbey is on a distinguished road
4-Axis CAM and Tool Path Problem
I have been playing with several CAM demos, including RhinoCAM, Rams 3D Gold, MadCAM, MeshCAM, etc. The ones that are able to generate 4-axis G-code seem to be limited to two basic tool paths; either perpendicular to the X-axis, i.e., circumferentially as the 4th-axis rotates, or parallel to it (more like indexed movements of the 4th-axis).
The part I need to mill would be more efficiently created if the cutter movement, for a given Z-axis depth, was largely along the X-axis, but was synchronized with small, continuous movements in the 4th-axis. The two paths described in the paragraph above create far too much up and down movement of the Z-axis.
Do any of the CAM programs with 4-axis capabilities offer such an alternative tool path?
Thanks.
Old 03-12-2007, 06:54 AM
thirumalkumarn is on a distinguished road
Try Latest Edgecam...
Dear Skibbey,
Try the LATEST version of edgecam it features various options and cycles.
Hope it may help your job. check the image attached
thanks.
Old 03-12-2007, 07:01 AM
cut more is on a distinguished road
Skibbey,
What you described sounds like what a friend does with pool cue inlays. This can be done with Bobcad it just takes getting used to. Can you post a cad file or a picture of what you want and I will try to help?
Cutmore
Old 03-12-2007, 08:03 AM
Image of Part for 4-axis Tool Path
I appreciate the reply, and have uploaded an image of the part. It's worth noting that the blades were extruded normal to the surface of the core, which is why a 4-axis tool path should be sufficient.
Thanks.
Name:	Helical Water.jpg‎
Old 03-12-2007, 08:12 AM
Skibbey,
I will play with this when I have some time, either later today or tonight and let you know how it comes out. What Type of post do you use? I will try & post some code for you too.
Cutmore
Old 03-12-2007, 12:47 PM
wms's Avatar
wms wms is offline
Moderator
wms is on a distinguished road
Skibbey,
Here is a link to a video with narration, I made doing this in OneCNC..with 4 axis wrap..took about 10 minutes..
http://64.26.25.102/wms/4axis_wrap_cnczone_wms.wmv
Old 03-13-2007, 10:05 AM
That's exactly what I was envisioning, and thinking of the "pockets" between the blades rather than of the blades themselves is a creative way of simplifying the task.
I'll definitely have to check out the software.
Thanks!
C axis tool path Capt Crunch Mastercam 1 12-20-2006 07:05 PM
need help fast 5 axis tool path in mastercam fasttom G-Code Programing 0 12-02-2005 12:22 AM
tool path problem fastolds BobCad-Cam 9 07-07-2005 12:01 PM
getting tool path problem kenlambert BobCad-Cam 0 01-14-2005 02:15 PM
Tool Path WOODKNACK TurboCAD/CAM 4 06-27-2003 07:27 AM
