Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 02-27-2007, 04:17 PM
Josh-PTP is on a distinguished road
Exclamation Cam Programming On ID 1/2-14 NPT Threads
Hey Guys,
I am currently using Kennametal’s new 2 Flute Thread Milling Cutter and using Kennametal’s new thread milling software off of there web page. There software has problems!! If you use the settings that they suggest, you end up with a pipe thread to deep and to big. I tweaked the program a little and finally got a good thread to a ASI-1/2-14NPT Gage. The only problem is that there is not enough chip clearance built into the cutter to cut the thread in the 2 passes that they want you to do. I was wondering if there is any free software out there that will allow you to program this Pipe Tape if you know what you Tool Dia is and length of cut. I am running BobCAD and awaiting on there tech support team to get me an answer back on weightier they can do it of not. I just thought I would put a post on here and see what everyone on here thought about it.
Thanks in Advance
Josh
www.ptpmfg.com
Old 02-27-2007, 06:10 PM
Kiwi is on a distinguished road
I understand BobCAD has a helix feature but not a tapered helix.
Are you needing a path for a single or a multi point cutter?
ID Threads phoodieman Daewoo/Doosan 27 01-03-2008 08:33 PM
Need help with threads Turk88 General Metalwork Discussion 2 07-27-2006 01:35 PM
New threads that are not new??? turmite Forum Questions or Problems 1 01-27-2005 08:52 AM
Saving threads or parts of threads??? flybynight Forum Questions or Problems 4 02-22-2004 12:19 AM
npt threads brtlatjgt General Metal Working Machines 3 10-23-2003 10:42 PM
