Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 03-09-2004, 09:18 PM
nervis1 is on a distinguished road
easy 3d cad program?
What do you think is the easiest 3d design CAD program out there? I'm struggling with my current CAD (actually I've tried three). I have this thought that 3d is just plain hard and I need to just keep my nose to the grindstone but still I'd be willing to shell out for something that was a bit more user friendly even if it was less functional, just to learn with a little less frustration.
Old 03-09-2004, 09:28 PM
DLMACHINE is on a distinguished road
My vote goes to Rhino.
Old 03-09-2004, 09:32 PM
I've read through the Rhino forum, and the price is tempting. Can you compare it to Acad? Better / worse in terms of ease of use and learning curve.
Old 03-09-2004, 10:47 PM
duluthboat's Avatar
duluthboat is on a distinguished road
nervis1
Rhino and AC are different tools for different jobs. They will both do 3D CAD. What would you like the software to do?
Gary
Old 03-09-2004, 11:52 PM
Gold Member
Ken_Shea is on a distinguished road
I have tried numerous Cad/Cam programs and this is my conclusion.
My expectations are not always reasonable or accurate and if they are easy they are not complete. There is a required learning curve to get the potential from any of them and they all have issues that will drive you crazy.
M2CW.
Ken
Old 03-10-2004, 12:26 AM
Learning curve definatley has to go to Rhino.
I have used Autocad and now I own Rhino and for the beginner I still vote for Rhino. If you are purchasing the software out of your own pocket Rhino has the advantage there as well.
Old 03-10-2004, 01:21 AM
Hobbiest is on a distinguished road
I have only used Rhino for 3d, but I have found it very user friendly. You can download a fully functional trial version for free. It only has 25 available saves, but by that time you prolly won't be apprehensive about the cash.
Stop talking about it and do it already!!!!!
Old 03-10-2004, 02:48 AM
motordude is on a distinguished road
3D cad
Hello Nervis.
I have used I-deas, AutoCAD, Rhino, Mechanical Desktop, SolidWorks and some others I don`t remember the name of. Of all these I prefer SolidWorks even if I-deas is more stable. It is not an advantage to have previous AutoCAD experience when working with SW, as it is another way of thinking, and Acad thinking only gets you confused. The good thing about 3D modelling is if you know one, it will take you a short while to learn another program. Get a parametric modeller. This means you can go back and make changes and parts in the assembly updates accordingly. Example: Two plates bolted together, measuring 100x100mm, 10 mm thick, ø15 hole in the middle. You want to change the dims , the thickness and hole dia. In a non parametric modeller you would have to fill the hole, then make a new, add or subract material. In parametric mode, just double click the dimensions, change and it`s done. You can change any parameter, not just the last one. You can swap the parameters. Ex: First you make a hole, then fillet. You find it is more advantageous to fillet first, then make the hole. You just intercange them on the history tree by the mouse cursor. The advantage is obvious when working on parts with many features in an assembly.
SW is expensive, try Alibre. Have no experience with it, but download a demo. Once you tried 3D, you will never go back to 2D. 3D is not more difficult than 2D, it`s just another way of thinking. Good luck with it!
Regards
John
Old 03-10-2004, 05:14 AM
Cruncher is on a distinguished road
Depends if you want to use it for cam or not. We use Solidworks and OneCNC. Onecnc is easier to use than solidworks but solidworks you can do assemblies and it is a parametric model cad. Onecnc you can work in wireframe solids or plain surfaces with built in cam. Design office uses solidworks and we use onecnc for all cnc work because it is easy to use. They have a great support forum and it is brilliant for the cam. 3D has a learning curve but when you know it is easier than 2D especially for cam. We have many files supplied by customers from rhino and we rarely have a problem with them too.
Old 03-10-2004, 06:04 AM
Moderator
Dan B is on a distinguished road
Rhino has great 2D tools too. The only area it is lacking is in advanced drafting tools. You can dimension, but it's no where as good as ACAD is in this area. But in Rhino's defense, most of these tools are available as add-ons or scripts. For example, I wrote an ordinate dimensioning plug-in that works very well in Rhino. I know of another script that adds hatching to Rhino.
I believe I read somewhere that this is an area that will be addressed in Version 4.
Dan
  #11   Ban this user!
Old 03-10-2004, 08:52 AM
Sinnister's Avatar
Sinnister is on a distinguished road
I made the switch from a 2D system to Solidworks, and it was difficult at first. However once I learned the basics of 3D modeling it was a breeze. I would never go back, it's ease of use is amazing.
Some folks, like blisters, show up after all the work is done.
  #12   Ban this user!
Old 03-10-2004, 10:40 AM
cadman's Avatar
cadman is on a distinguished road
I use both Rhino & SolidWorks and SolidWorks is hands down the best midrange 3D modeler I've ever used. Rhino has some good surface tools that I use to create or edit surfaces that SolidWorks has a little trouble with, but that is fairly rare. It should be pointed out that SolidWorks is designed primarily as a mechanical engineering application and Rhino is designed for industrial design and even so, SolidWorks holds its own when used as a industrial design tool. If I could afford it, I would rather use Alias or Thinkdesign for my design work.
Oh, whats the easiest to use 3D software? Rhino for design, SolidWorks for everything else.
CAMback easy - One Program for ALL Machines!!! [free DOWNLOAD available NOW!] CAMback Product Announcements & Manufacturer News 9 11-06-2007 08:29 AM
parametric programming Karl_T CamSoft Products 21 05-24-2005 02:58 PM
=> New CAD Projects Available CAD Ground Employment Opportunity 3 05-16-2005 02:45 PM
CAD Drafters Needed CAD Ground Employment Opportunity 0 03-11-2005 11:05 AM
Cad program to map parabola rickwinters General CAM Discussion 8 02-23-2005 12:04 PM
