Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 02-22-2007, 04:32 PM
IAD IAD is offline
IAD is on a distinguished road
DIY Router Control/GCode Generation?
Hello...
I'm a rank newbie here, but having read up a bit, I've started trying to come up with the list of software I'll need to go from a Rhino 3D model to Gcode to a parallel-port DIY router...
At this point, I'm looking at using Rhino3/4 to model, madCAM to generate the toolpath/Gcode, and then MACH3, to run the router.
Would this combination work, and are there other options I should be aware of? (I'd prefer to keep things as inexpensive as possible. At the same time, I will be milling [flying] model airframe components, so accuracy is a big plus.)
I did look at Freemill, but as has been pointed out repeatedly, it's pretty rough, and doesn't run reliably on my machine here, anyhow.
Thanks!
~Luke
Old 02-22-2007, 05:36 PM
ger21's Avatar
There are a ton of options available for CAD/CAM, from free programs to tens of thousands.
If you're cutting mostly balsa and ply sheets, take a look at SheetCAM, at www.sheetcam.com It will work with any inexpensive CAD program that can save a .dxf (all of them). DesignCAD and TurboCAD are two good ones. You can pick up slightly older copies (new in the box) for about $20-$30 on Ebay. Both are under $100 for the current versions.
If you need 3D, look at MeshCAM, www.meshcam.com
I always recommend to download the trials, learn how to use them and know what you're paying for. I've seen a lot of people pay for CAM software that they don't use. Do a lot of research before you spend your money.
Old 02-22-2007, 08:46 PM
IAD IAD is offline
Well, I definitely need 3D. Most of my work will be carving fuselages/wings out of blocks of foam. (Compound curves, and what-not.)
I saw MeshCAM, and while it looked good, I like the idea of a Rhino plugin, since practically all the modeling I do is in Rhino3.
I will of course be experiementing with the demos, and what-not, but hearing other people's experiences is very helpful for me, as well.
~Luke
3rd Generation Router Build yukonho DIY-CNC Router Table Machines 65 03-28-2007 09:45 AM
RealBasic Attempt for CNC gcode generation originator Visual Basic 1 11-26-2006 06:21 PM
Router speed control ljoe1969 General Electronics Discussion 4 08-01-2005 08:13 AM
2nd Generation CNC Router Design 32.5” X 14” X 6” gregmary DIY-CNC Router Table Machines 9 03-24-2005 04:46 PM
I have a problem with my gcode or my conversion to gcode , everything is tiny? NickLatech G-Code Programing 0 03-10-2005 12:46 PM
