Results 1 to 6 of 6
Thread: Need Software to Drive Steppers
    Feb 2004
    Turkey
    I just finished my mome made CNC milling machine. I tested it with KallyCam software, there is no bug yet. (can be seen at http://gunol.otocamlibel.com )
    But I want to use softwares to drive my machine other than KellyCam
    It must be a software that imports G-Codes and drives my steppers via parallel port.
    What are these parallel port driwing softwares?
    I use AutoCad to prepare dxf files and import them in to KellyCam software to convert G Codes and drive my machine.
    I have also Mastercam and Surfcam demo softwares.
    As seen I solved designing and G Code generating problem.
    But I need some software to drive my steppers according to these G Codes
    Gunol Camlibel
    gunolcamlibel@rc-tuning.com
    http://www.rc-tuning.com
    Mar 2003
    Shelby Twp, MI....USA
    Most people here use either TurboCNC, from here:
    http://www.dakeng.com
    Or, Mach2 from here:
    http://www.artofcnc.ca
    I wrote a Gcode exprting macro for AutoCAD that you can get here:
    http://www.cnczone.com/showthread.php?threadid=2443
    It writes the g-code right from Autocad so it saves you a step.
    Feb 2004
    Turkey
    I will try all of your suggestions.
    Thenk you for your quick support
    Gunol Camlibel
    Mar 2003
    There is a newer version of TurboCNC that you should use in the file section of the yahoo group. The link to the yahoo group should be at dakeng.com .The version you want is 3.24c.
    Feb 2004
    Spain
    Hey gcamlibel, I've seen your router, looks good. Could you post some schematics of your driver board and lpt board?
    thanks in advance
    /U
    Feb 2004
    Turkey
    my control and power cards designed on pierre's cards.
    this is his own web page about these cards :http://www.otocoup.com/CarteL6208_e.htm
    there is lots of data about these cards.
    Check this web page, if not enough turn back to me ok?
    Gunol Camlibel
    1. Engraving Software
      By The Wizard in forum General CAM Discussion
      Last Post: 03-29-2005, 06:38 AM
    2. Torque of 5 1/4 FH Drive Steppers?
      By Rance in forum Stepper Motors and Drives
      Last Post: 03-09-2005, 02:22 PM
    3. ***One stop CNC software guide***
      By ynneb in forum DIY CNC Router Table Machines
      Last Post: 05-27-2004, 05:31 PM
    4. Are all steppers microsteppable?
      By Greg Fill in forum General Electronics Discussion
      Last Post: 04-25-2004, 04:57 PM
