Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 02-12-2007, 10:08 AM
sintratech is on a distinguished road
Autocad 2005 and mach 3 nesting
I am looking at cutting centering rings or donuts if you will for rockets. Does anyone know how I can nest multiple donuts so I can cut at least a dozen or so of these donuts in one run? Also how do I cut the center diameter hole before it cuts the outter diameter?
Old 02-12-2007, 10:21 AM
ger21's Avatar
You can use the AutoCAD macro I wrote to create your g-code. Draw your concentric circles, allowing for the tool diameter, and the macro will let you select the cut order and create the g-code.
http://home.comcast.net/~cncwoodwork.../AC2GCv039.zip
AutoCAD to Mach 3 N4NV Autodesk Software (Autocad, Inventor etc) 5 02-16-2007 06:14 AM
Projecting Line, Autocad 2005 Nmbmxer Autodesk Software (Autocad, Inventor etc) 2 04-04-2006 09:46 PM
2D On-Line nesting - Nesting on-demand ! mijo Product Announcements & Manufacturer News 0 03-21-2006 09:42 AM
