Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 01-19-2007, 06:45 PM
chase78 is on a distinguished road
Digitized *.STL to Workable CAD File?
I'm going to Be getting a 3D Digitizer that will give me a dot plot in *.stl . I work In Solidworks. I'm looking for sometype of parametric program so that i can work with the digitized object in SOLIDWORK.
Any suggestions?
Old 01-19-2007, 06:51 PM
ger21's Avatar
You want to turn a digitized model into a parametric model?
Old 01-20-2007, 05:32 AM
Kiwi is on a distinguished road
SOLIDWORKS 2007 will open a STL file.
Old 01-20-2007, 10:09 AM
cadcam's Avatar
Community Director
cadcam is on a distinguished road
So is this going to basacally give you point cloud data?
If so then you will need to make splines from this data to create surface data.
SW should support this.
Cadcam
Mastercam Instructor , Programming Consultant and ME (Manufacturing Eng)
Old 01-20-2007, 10:35 AM
cadman's Avatar
cadman is on a distinguished road
SW opens stl files. But unless you have a good graphics card and lots of memory, SW is very slow to open stl files with a large number of polygons and is prone to crashing. If you are working with a stl file that has 3D contour surfaces this is what you will have.
That said, many digitizers have plug-ins to scan and import point cloud data from within Solidworks. Maybe that is available with your device. If not, do a search on Desktop Engineering magazine's website.
www.deskeng.com
They have done many articles on digitizing and related software.
Old 01-20-2007, 11:24 AM
"You want to turn a digitized model into a parametric model?"
yes thats what i want to do.
The 3D digitizer gives a point clound. I'm Working with SolidWorks 2004 So I can open the file but it give me no dimensions of ablity to manipulate it.
I know programs like Rapidform will get the job done but I don't that kind of money.
Old 01-20-2007, 11:54 AM
ger21's Avatar
I don't believe there's a cheap or easy way to do it.
Old 01-20-2007, 03:45 PM
A program MeshToSolid is a Plug-In for IntelliCAD. $195 USD
Each MeshToSolid license comes with a free commercial license of IntelliCAD worth 250 USD.
http://www.sycode.com/products/mesh_to_solid/index.htm
When opened as STL and saved as SAT this can be opened with BobCAD-CAM, measured and tool paths generated.
Old 01-20-2007, 05:09 PM
cadcam's Avatar
Community Director
Well in that case I can cut an STL in Mastercam under that thought.
I think he needs to see if it will output say Ascii formate so you get the point data and build from there.
Cadcam
Old 02-01-2007, 02:41 PM
Tony the Ferret's Avatar
Tony the Ferret is on a distinguished road
Wink stl to cad
Think you need to look at re-eng from Cimatron, it has the ability to read in an STL file, trim and cut it with surfaces & planes, then add it to a surface or solid model.
Downside of any STL files, they will never be a parametric entity, because it was created with fixed points from an external source. Of course you may be able to pull or push the points to alter the shape, but this is not parametrics. You need to remember what a parametric entity consists of, for example a simple line.
The creating software knows the co-ordinates of the start and end in XYZ and of course the vector. if this entity is used for any other construction or part of another entity, the software knows everything about it.
Between parametric modelers, eg SW & Cimatron, there will never be the ability to parametricly alter an entity, because there is a different type of HISTORY.
End of lesson 101
Old 02-01-2007, 02:58 PM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
SolidWorks has an ADD-IN called "scan to 3D". It is specifically made for turning an .stl point cloud into a solid.
It comes packaged with SolidWorks Premium and I would imagine you could purchase it as a stand alone add-in.
Contact your reseller.
If you have any way of scanning as an .stl solid SW opens that without any additional operations.
www.integratedmechanical.ca
CNCmill, 'Paxton/Patterson' workable? File Benchtop Machines 17 04-16-2006 11:44 AM
php file larry53 Forum Questions or Problems 1 09-14-2005 10:26 AM
Drawing Tablet (Digitized) Woodie1 General CNC (Mill and Lathe) Control Software (NC) 1 05-21-2005 02:52 AM
Anyone want to help me with a file? nervis1 Mastercam 19 05-12-2005 05:06 PM
.INI file JOE65 TurboCNC 7 03-21-2004 12:46 AM
