Results 1 to 10 of 10
Thread: dxf to gcode problem...
    Feb 2004
    Colorado
    Boy, I feel like i am stumbeling throught this process and cant seem to get one thing done without help.
    So here I am again! I have learned a lot so far, but I have this file that I have tride to convert to gcode using ace that is not working. I was able to get gcode of the 2d version but now the 3d is not working.
    I have attached the dxf and the gcode generated.
    Feb 2004
    Colorado
    Would help if i actually attaced a file...
    here it is
    Attached Files Attached Files
    Registered Jennifer's Avatar
    Jun 2003
    San Diego, CA
    The only thing I can see is that you've got double entities, which is probably why your program doesn't get further. I don't know the program you're using, but if you can do something along the lines of picking a chain and blanking it, you should be able to see where you've got these little beauties.
    Good luck!
    Jen
    Registered JOE65's Avatar
    Apr 2003
    I tried your file in Ace and got the same problem.
    I then used Autocad to save as an Acad r12 .dxf this helped quite a bit .gcode here
    Apr 2003
    UK
    I havent downloaded the fiel yet, so excuse my ignorance....I never thought Ace could do 3d? The way I use Ace is to put different height section on different layers, then using Ace's features, you can set each layer to be cut at a different depth from a set z=0 location. I will now go a download the file and take a look!
    Mar 2003
    Shelby Twp, MI....USA
    Ace doesn't like polylines, which is what the heart and cross are. Explode them, and any other lines that are more than 1 segment, and re-export your .dxf. That should work.
    Also, Ace won't read 3D objects, but what your doing, adding thickness, is not really a 3D object, just a line with thickness, so it will work as Ace just thinks it's a line.
    Apr 2003
    UK
    Nope, I can't get it to work either. Even with exploded lines, and only converting layer3 all I get is a mumble-jumble of garbage! Joe, I took a look at your g-code, but it seems to be cutting the whole thing at z=0. I think what freezer was trying to achieve was to get the three entities - cross, flames and the base - cut on different z levels.
    Freezer, if I am wrong about this, please let me know, but I think you would make life easier for yourself if you just stuck to a 2d drawing, with each entity on a seperate layer, and then tell Ace to cut each particular layer to a different z height. But like Gerry says, don't forget to explode everything first.
    Feb 2004
    Colorado
    My end goal was to give it a true 3d appearence. This has been my learning project. Giving the heart a convex shape and make the flames more realistic with some depth. My cad skill are loooow. I am trying to under stand the process of getting a cad drawing to gcode but it seems easer said than done.
    You are correct in sticking with 2d for now! The reason i started building my cnc router was to do simple 2d cutting but then i started thinking!!!!! 3D how cool...
    I belieave i under stand that when i draw a 2d image i will have to explode it before i try to convert it to gcode. With 3d i have to convert it to a polyline make it 3d then explode it and then make the gcode.
    I did try to explode this file and convert but it did not work either. I think on this my best bet will be to stick with 2d and add a small piece of trim that will save the time milling the entire serface any way. But, what i would like to do is add some depth to the flames where the base of the flame is .5 and the tip of the flame is 0 or something close maybe a 1/16th.
    Apr 2003
    UK
    You are heading in the right direction, but you will need different software than Ace. If your cad software can output stl, which I think Turbocad pro 9 will, then you can try Meshcam. Have a hunt around these forums, there's lots of info about it. This will help you create a 3d toolpath for those flames, whereas Ace will not.
    Apr 2003
    Southern California
    If you're not to familiar with CAD yet then you might try the image machining features of MeshCAM ( http://www.robgrz.com/meshcam.phtml ). To start you can draw the image as a solid and then apply a gausian blur in your paint program to give it a curved edge.
    Robert
    1. G-Code to DXF
      By WayneHill in forum OpenSource Software
      Last Post: 05-20-2013, 10:28 PM
    2. Beginner Troubleshooting and Building Considerations
      By coherent in forum FAQ of CNC Machine building
      Last Post: 11-10-2011, 02:27 PM
    3. DXF -> Gcode (lathe)
      By Gujustud in forum General CAM Discussion
      Last Post: 08-24-2010, 09:28 AM
    4. Replies: 0
      Last Post: 03-10-2005, 01:46 PM
    5. Gcode to DXF?
      By balsaman in forum General CAM Discussion
      Last Post: 04-30-2003, 06:40 PM
