Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 11-19-2006, 12:21 PM
mikede is on a distinguished road
What is the best 5 axis cam program for Tire molds/models
Company I work for makes tire molds. 2 way to make a tire mold. 1st way is to directly engrave the tread into steel or aluminum. 2nd way is to mill the tread pattern into a wood like model that has casting shrink added. Then cast the tread from the model ( couple other interim steps involved so you can save the model). Both methods use a lot of 5-axis machining. We currently use a custom out of Acad translator for the 5 axis model work. We use Unigraphics for the direct tread engraving. Unigraphics allows great 5axis modeling and CAM BUT we need to write a lot of automation to be able to use it efficiently. The 5 axis model program is fast but has limits on what processes it can do and obvious viewing issues. Its only 2d in AutoCad. We are having demos done by NCL, DELCAM, TEBIS, and HYPERMILL. All have a tire module. NOW FINALLY the questions. Does anyone have any experience with these products? What are your experiences and opinions on the products? Should we change from UG to 1 of the products or bite the bullet and write the automation?
Mike DeBerry
Old 11-19-2006, 09:58 PM
turmite is on a distinguished road
HI Mike,
I can't speak to your 5 axis cam need but for modeling the tires Rhino would be great. Version 4 is about to hit the market and it has some features in it that would make the tread modeling a snap.
Where are you loacted in the US? I have a atv tire nearly finished modeled and need some info as to tire industry contacts.
Mike
No greater love can a man have than this, that he give his life for a friend.
Old 11-20-2006, 08:55 AM
cadman's Avatar
cadman is on a distinguished road
We are an NCL shop. Most of our parts are medical, aerospace and cryogenic (inducers, diffusers, impellers, etc..) and have very complex geometries. To sum it up, NCL can do anything you want and you have complete control of your tool paths. It is multi-axis software, period. It is not 3 axis with 4 & 5 axis options.
The downside: steep learning curve, very little automation as far as canned pocketing and surfacing goes, somewhat primitive interface, and editing can be a nightmare if you are not proficient in NCL. Also it does not use solids. Strictly surfaces & wireframe. There is an option for importing SolidWorks bodies though.
For 3 axis work look elsewhere. If you have complex 5 axis parts, NCL is 5 axis. For model creation, use a separate cad system.
Old 11-21-2006, 08:25 AM
Turmite,
We used Rhino at the last company I worked for to create 3d models for Powerinspect. I'm really looking at something that will take in the 3d model from the tire company and allow us to manipulate it. Located in the US but don't have much contact with the actual tire companies. Good luck with the ATV tire design.
Mike
Old 11-24-2006, 11:45 PM
biomed_eng is on a distinguished road
www.nccs.com has 5-axis software solutions specifically for tire molds.
Old 11-25-2006, 01:13 AM
CNCRim's Avatar
Mikede, UG is one of the best 5-axis out there I think. I don't think any other CAM can do any better than the one you have, but it doesn't hurt to ask for a demo.
Old 11-25-2006, 06:16 PM
Jacktak is on a distinguished road
I have experience whit Hypermill, have seen demos by Delcam,Tebis,Powermill,Cimatron and Hypermill. We made a very complex part, gave them an hour each... Hypermill made the part in 40 minutes. None of the others could get the job done, some of them, not even close. But but, read in the Hypermill forum, that their support in English are bad... I am from Denmark, we learn German in school, so we have no problems...:-)
Old 12-06-2006, 09:37 AM
Tony the Ferret's Avatar
Tony the Ferret is on a distinguished road
No mention of the excelent 5 axis solution from WorkNC. easy to use then just forget, the toolpath comes with built in machine aviodance and collision checking, gone are the days of the CAM system telling you "THERE WILL BE A COLLISION at node point 2345343 to 234571". Check it out.
www.foregonesolutions.co.uk
Old 12-06-2006, 11:53 AM
blowmebigtime is on a distinguished road
I program and run a five axis machine using Delcam's powermill,,, the automation part of Delcam is very good,, (writing macro's and templates, VB's and such) I have never made a tire mold but I would assume I could accomplish this in powermill quite easily. After using powermill for a while I was doing research and it seems like Unigraphics has the BEST there is as far as 5x work. Delcam, Tebis, and Work NC, a close second. Mastercam, surfcam, hypermill, onecnc, camtool, pro-manufacture,, ext... ext... , great for 3x work but when it comes to the real stuff it's not even close in my book.
Old 12-06-2006, 01:37 PM
I was using UG for 5 years befor i started using WorkNC, in my mind there is NO comparison, i could do things with WNC in a short time that i never got to grips with in all the 5 years on UG , Training for UG was in total about 10 days, I had 2 on WNC and will never look back, I have so much confidence in the product i am now selling it as an independant agent. Have trained Delcam users in 1 day, they will never let go of WNC. Don't need all the macro's or VB's. WorkNC will just get on and cut.. I offer a challenge for anyone to program a part quicker than WorkNC. That is in 2,3,4 3+2 of full 5 axis... Send me the part!!!!
  #11   Ban this user!
Old 12-06-2006, 02:00 PM
That is one thing I heard about UG and to some degree powermill as well,, and that is there is a huge learning curve. Delcam has so many different toolpath strategies that it can get overwhelming to a new user..
  #12   Ban this user!
Old 12-06-2006, 03:46 PM
Easy
From my experience, and asking P/M users, they say if you manage to be an expert, you can get by, but it is very difficult to teach new users, and especialy those who are only occasional users.
WorkNC has approx 50 toolpath types, but the common interface lets any one create paths in a very short time. See the attached. It may seem Quirky, but it really allows you to crack on. The other fantastic time saving thing, is the ability to create toolpaths whilst a calculation is in operation, then when the calc is finished, the uncalculated can be started.
With UG, we had to purchase Vericut to simulate the toolpaths on the screen. But had to wait for all calculations to finish. So i spent long hours looking at a calculation screen, could not do anything else, cad was locked, could not pp, could not lay down new toolpaths..........Ho Hum, have a walk round the shop......
ID:	26809   Click image for larger version
