Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > General CAM Discussion
General CAM Discussion Discuss CAD/CAM software and Design software methods here!
Old 10-19-2006, 03:23 PM
diarmaid's Avatar
*Registered*
diarmaid is on a distinguished road
Unhappy Please Help Me With INKSCAPE
Ok, so I want to convert raster to vector so I can put ',dxf' designs into the V-Carve Pro competition and win myself some free Vector Art 3D designs!!
Anyway, I downloaded InkScape to use it for converting into vectors and I can't seem to do it. Below is the process Im following. Please tell me where Im going wrong?
STEP 1: First I draw my picture then make sure its selected with the arrows around it.
STEP 2: Then I select the menu option 'Path' and 'Trace Bitmap' giving me the dialog box in the 2nd picture below.
STEP 3: As in the 2nd image below, I then click on 'Preview' and outside the dialog box, on the bottom of the screen, it says 'Select Image to Trace'.
STEP 4: I then try and select the image outside the dialogue box as shown in the last image, but my dialogue box goes behind my window and nothing seems to be happening....
Please help...
ID:	24287   Click image for larger version
ID:	24288   Click image for larger version
Old 10-19-2006, 04:59 PM
ger21's Avatar
The "picture" your drawing is already made up of vectors. Have you tried just saving as .dxf? I have Inkscape installed, but only played with it once. I don't believe it has any raster drawing tools, does it?
Old 10-19-2006, 05:25 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
i dont think you need to trace ,have you tryed simply saving the drawing as a dxf file
i beleave the trace is only for image files
Old 10-19-2006, 05:52 PM
diarmaid's Avatar
*Registered*
Thanks for teh reply Dertsap,
I tried saving as DXF but when I opened it in the trial version of VCarve Pro, I got the error message below, which Im not entirely sure what it means.
InkScape was recommended to me for converting bmp into vectors that I could route with Mach3, so Im sure it works somehow...?? However, I may very well be mistaken. Any other ideas?
Old 10-19-2006, 06:10 PM
diarmaid's Avatar
*Registered*
This is very strange!
I saved it as an *.eps file in inkscape instead of as a *.dxf and it imported into PhotoVCarve fine as shown below. Thats great as I can do stuff now, but I want to know why dxf doesn't work?
I get an error message when I save in ANY file format in InkScape saying that some information may be lost but since it always happens and eps file worked I dont think its relevant.
Old 10-19-2006, 07:07 PM
dertsap's Avatar
Gold Member
ive used it to convert images but i havent used it for anything else , its incredible how well it converts bitmap , to vector , when i add the dxf file to artcam the picture comes out really good
Old 10-19-2006, 07:57 PM
ger21's Avatar
Download the .dxf converter from www.a9tech.com and convert the .dxf to a different format. Although apparently now you don't need to.
Old 10-20-2006, 10:03 AM
Tony Mac is on a distinguished road
Hi Diarmaid,
Glad to see you are using InkScape - It's a great Free conversion program!
We recommend that users Save As = EPS from InkSacape as this file format will retain any curves in a design ad bezier spans. The DXF file format will does not support bezier curves and will almost certainly convert them to poly-lines (point to point lines) that will not give the same quality when machining.
The error message you see in VCarve Pro simply means the file does not include the DXF file version in the header so VCPro attempts to read it as version 12 DXF data.
I hope this helps,
Tony
Old 10-20-2006, 04:53 PM
diarmaid's Avatar
*Registered*
dertsap: Yeah, I've converted a few detailed bmp scans using it now and its really great.
ger: Thanks ger, that link is very useful, but I think Im going to stay with Inkscape for the moment, at least until I get my head around it. One program at a time!
Tony: Thanks Tony. That explains the error message in VCarve. I guess .eps it is! No need for .dxf anyway. .....Any hints for how to win the competition?
Old 02-01-2007, 05:23 PM
sanddrag is on a distinguished road
Turns out that the Windows version of Inkscape doesn't include the AutoCAD DXF export (only the Desktop Cutting Plotter DXF export) which will not open in AutoCAD (or anything else I tried). The kind of ironic thing is that the Linux version of Inkscape does include the AutoCAD DXF export (which is ironic because there isno autocad on linux), and it works just beautifully.
Inkscape is in the ubuntu linux package repositories. sudo apt-get install inkscape should do the trick.
Well, I tried out linux, and it didn't show the AutoCAD DXF export in there either. Turns out, I needed pstoedit, and didn't have it. So, you've gotta get pstoedit. It is in the universe repository. You can get it through synaptic, and then get whatever other stuff it says goes with it. And I had to do a distro upgrade. Anyway, it is all well and good now (on Ubuntu 6.10). Works great.
  #11   Ban this user!
Old 02-02-2007, 03:06 PM
thkoutsidthebox's Avatar
thkoutsidthebox is on a distinguished road
That's true sanddrag,
I found this out trying to import to NCplot for generating G-code, but you can get around it by opening the Inkscape file in 'CamBam' which is a great free program. Then just re-save it in CamBam which is the correct .dxf format.
  #12   Ban this user!
Old 04-04-2007, 06:01 PM
Glidergider is on a distinguished road
I spotted this tread and another like it, so I downloaded Inkscape for a test ride. I'm sorry to say, I can't get it to save any vector information. I was able to take a jpg file, convert to gray scale and generate vectors. Then when saving to either dxf or eps, VcarvePro said no dice. There was not vector data in the file.
Any ideas? Like I said, I got vectors to be created using the Shift+alt+B command.
Dave
